ri702bill
A Flushin' We Will Go
peter lena
@ri702bill  terrific  opportunity thought !  what a concept !  love the idea  of road testing and verifying an improvement . like to look at intended operational function , and improve on that . very often just a small detail change makes it function so much better.. on my road flush drives , been using ATF  fluid as a cleaner fluid , think it does a very thorough flush and drain down . keep it oily , pete
ri702bill
And is probably cost effective too - I paid $5.19 for a gallon of Diesel the other day.
Bill
WHX??
You got it stripped down that far Bill I would be tempted to split it and check things out.
  • Like 4
  • Excellent 2
peter lena
@ri702bill  being a lubrication nut , regularly look for lubrication / change results to any lubricant . if it works better  smoother . easier and lasts longer , why not go that way ?  pete
ri702bill
@WHX?? I might just do that with the noisy one first - never had the need to open one up - yet ....
Bill
Pullstart
Could you have twisted a longer belt?  Regardless I’m glad this isn’t a toilet or a plunger thread!
  • Haha 2
ri702bill
Like an old Corvair???
No toilet humor here - yet - not by me :happy-bouncymulticolor:
Pullstart
Yeah.  :handgestures-thumbupright:
stevasaurus
Actually, all you had to do, turn the motor around so the pulley is lined up and the motor is on the right side.  Or figure "8" a fan belt, like Kevin said.  :occasion-xmas:
  • Like 4
ebinmaine
  On 3/29/2022 at 12:16 PM, ri702bill said:
If you think you MAY have a seal that is leaking
You probably do and you should replace it anyways.
Bill
I wouldn't be just tempted Jim. I would have already started by now...
Bill, go ahead and pop that thing open. Pretty interesting stuff inside there.
No toilet valves mind you, but still pretty interesting stuff.
ri702bill
OK just need to get a 3912 gasket .....
wallfish
It is not easy to find a 110-volt motor that has reversable rotation.
True! Where did you find that one or was it something you already had?
I don't think it would hurt the trans to run it in reversed rotation. Might even help to run it both directions when cleaning it out too. :dunno:
  • Like 4
stevasaurus
It shouldn't hurt the trans to run it in the opposite direction, but if you look down the shifter hole when running it in the counter-clock-wise direction, you will get the appreciation for how the transmission oils itself.  It is worth the look !!  :occasion-xmas:
  • Like 4
ri702bill
Yup - the Parts Department coughed up a worthy motor...from the "I just MAY have a use for this thing, but not just now, I'll leave it here shelf !!
Bill
  • Haha 4
Wheelhorse#1
Great idea.Thinking outside of the box.That should of really got the juices flowing !
wallfish
Is this like telling the kids to look in the end of the garden hose to tell me when the water is coming out? LoL
  • Haha 6
  • Heart 1
Pullstart
I could still use that one!  Maybe not with my kids, but surely with my inlaw’s kids!
  • Haha 1
Handy Don
Hey @davem1111, check out the top of this thread. Got a spare motor to hook up to test your 700?
Edited by Handy Don
gt14rider
Just turn motor around to change direction, short belt,just let motor hang for tension.
  • Like 4
stevasaurus
This is from 2011...Brrly1's #5007 tranns.
  • Like 6
davem1111
Unfortunately I do not... probably should have pulled the motor from the old wash machine before scrapping it last year. :eusa-think:
I love ideas like this, and the challenges that prompt our brains to come up with them. :techie-idea:
Handy Don
Be thankful, @davem1111, that you clearly do not have the "I can't throw that out, it might be useful someday" disease.
Me, I'm sitting on three old motors (one with a switch for forward and reverse!) that I've been hanging onto "just in case" right next to a big box of scrap metal that I very occasionally mine for some project or repair. Something's gotta give here.
Edited by Handy Don
  • Haha 1
davem1111
Actually, I *do* have more than a mild case of that disease, but when my wife looks around the garage (which doesn't happen very often), there usually has to be some at least "token" sacrifice... :D
  • Haha 2
stevasaurus
No problem, if you do not have a motor.  You can use your horse.  :eusa-think:
