Wheelhorse#1
Piston Size
Wheelhorse#1
Did Kohler stamp the piston size on all of their pistons? Only way to know for sure is to measure ?
This is a K-181
Edited by Wheelhorse#1
squonk
Nothing means STD.
  • Like 4
WHX??
A .003 can also mean standard or factory piston.  It escapes me why Kohler did that. Other than that all will  be stamped .010, .020 .030.
Achto
I think this was done to compensate for machining errors.
953 nut
Like @Achto said.     They wanted to be able to use the blocks that came through while the machinists were having a cup of coffee or whatever.   :text-yeahthat:
  • Haha 2
WHX??
And I just read that in the manual the the other day and you think I could remember?!?!? :lol:
I do remember the manual didn't mention a cupojoe 'Nut!
  • Haha 2
WHX??
Not too far :offtopic:Dan I did find this.... 'course this may not apply to aftermarket rings???
Edited by WHX??
  • Excellent 3
Wheelhorse#1
All .Thanks for the great info,very much appreciated .I have a set of standard NOS rings I bought a wile back.
This 8horse I bought  for a song and dance and a couple wooden nickels! With just minor maintenance, it runs great and zero smoke.
Inwas thinking of throwing rings in it but after looking at the cylinder It looks surprisingly good.
I guess at some point it was at least re-ringed,can even see the cross hatches still there.
I was amazed when I got these Kohler rings in the mail.
Now that’s what I call quality .The price marked  on them is $13.25😉that’s certainly not close for what I paid for them,
Wheelhorse#1
Does this piston look too worn? Replace and re ring it and hone ,what would you do ?
It’s going on a B-80.Main use to cut grass and pull a cart around the back 40.
Wheelhorse#1
Delete
Wheelhorse#1
squonk
I have seen pistons erode there on several engines. It's the hottest point during combustion. The exhaust flame is just going to beat on that area more to the point of directly effecting the top ring. If this was going to be just a put put tow me and the grand kids around tractor, I'd consider leaving it. Put if it's going to mow,plow snow and work, I'd replace it and have a machine shop check the cylinder.
Wheelhorse#1
Thanks Squonk
I’ve seen this piston wear in all three WHs I bought .Figured it was due to heat as you said it is the hottest point at the exhaust valve.
I’m going to do the math as explained By 395nut  in the thread at the top  (Can I just hone the cylinder) Poor mans machinist .I fit that category !
