The Gman
654 Update
wallfish
19 minutes ago, The Gman said:
Still looking for diodes for the charging
Contact Cas  @formariz but tagged him here too
WHNJ701
Since those old lausen/Tecumseh ignition parts are getting very expensive and difficult to find, I removed the electronics and charging and just use the pull start. Usually 1st pull and its running
Edited by jabelman
WHX??
You guys need to check this out on the diodes...found it in the basement.
Edited by WHX??
Snoopy11
2 hours ago, The Gman said:
Finally finished the H60 for the 654.
HECK yeah buddy! Hell of a job. :banana-dance:
Shout out to Snoopy for providing the crankshaft for this little fella.
Aw shucks...
Glad to help. I do have a spare flywheel for the H60 laying around... as well as a few other parts around here somewhere... so if you need anything like that, hit me up. :handgestures-thumbupright:
Don
Pullstart
Nice work, that paint scheme looks awesome too!  @Snoopy11 is that really you?  :orcs-cheers:
  • Haha 1
Tractorhead
Great job on the Engine,
i looked also for that diodes for my hh60 the first time
but they appears to be very rare or expensive.
I used a normal rectifier instead and let the original diodes sit on the Engine because of the Optics.
one possibillity is to make you one yourself with high Power Schottky diodes at 10A rating.
they be available with a fit plastic cover for a few cents.
two metal caps and you be good to go.
Snoopy11
I'm still around... lurking in the shadows... :hide:
I might start coming around a little more... cautiously... :ph34r:
We'll see...:handgestures-thumbsup:
Don
