OutdoorEnvy
C-Series gear oil fill location?
OutdoorEnvy
I have a C-100 and thought it would fill through the dipstick tube hole.  But that hole is tiny and no fill funnel is small enough to fit and gear oil is just going everywhere.  Is there another fill port or what's the trick for the C series gear oil filling?
ebinmaine
The best case scenario is to remove the shifter.
When you put it back replace the dog point set screw and shift boot.
Handy Don
As in unless the boot is in excellent condition, a new boot. :rolleyes:
Maxwell-8
Maybe get a pump that fits on the screwcap, and remove on of the bolts on the gastank support
OutdoorEnvy
Well got to looking and made something work.  Found an old bottle of gear oil with the little cone end cap.  Cut that small so it would press into the small dipstick tube hole.  Then was able to push in a small funnel to that one and it did work.  Just slow going with the pouring and waiting for it to drain.  But did get the job done.
  • Excellent 2
ebinmaine
I've done something similar in the past. Worked pretty well.
Just get the funnel so it will sit steady and not fall over. Pour a few ounces in and walk away for a while. Repeat. Repeat.
OutdoorEnvy
That was pretty much the drill!  I was also working on the 312 so made the back and forth not too bad.  Got it filled over about 20-30 mins or so.
  • Like 4
Pullstart
Next time… if you unscrew one of those 3/8” bolts next to the dipstick tube, that’ll give the air a place to go :handgestures-thumbupright:
  • Like 9
ebinmaine
Got to be a joke there somewhere about flatulation and having a screw loose.
Welcome to the mind of the Large Bear.
  • Haha 4
SylvanLakeWH
:text-yeahthat:
Or a straw on side of funnel…
used both - they work.
  • Like 4
Horse Newbie
When I filled the 8-speed on the Work Horse I used a bottle of gear oil with the cone on top… just squeezed the oil out and it did not flood the dipstick tube which is I guess 5/8ths to maybe 3/4 inch in diameter.
It worked well and when the bottle was almost empty I just stood the bottle upside down until the bottle drained.
Of course I had removed one of the seat support bracket bolts so it would vent also.
  • Like 6
clueless
That will work but you blocking the air that needs to vent (slow go). like a couple of my boys here said next time remove one of the bolts next to the fill hole it will go a lot faster. Also if you drained the old out did you jack the front of the tractor up at least 18 inches?
daveoman1966
Easy and quickest way I've found:
  • Like 6
OutdoorEnvy
You don't say....that information would've been useful 4 hours ago!  LOL!  :-D
Definitely will keep that in mind for next year....when it looks like chocolate milk again... Thanks for the tip
  • Haha 1
OutdoorEnvy
I did indeed!  Used my 3 ton truck jack at full reach on the front!
briankd
2 hours ago, SylvanLakeWH said:
:text-yeahthat:
i tried that on my c 145 and made a mess forced plastic funnel into dipstick tube tight fit  and  poured it full it gurgled  the air out and went down took awhile not too bad tho but got the almost 5 quarts in it
Edited by briankd
