Geochurchi
B&S Vangard
Geochurchi
Hi All, we have a Vangard engine, trying to determine what the correct ignition switch would be , it has a magneto ignition system, right now we have a 5 terminal switch, not sure how the ignition kill switch is connected or does the switch short to ground internally , this motor is on a small garden style locomotive, so not much else to go on.
R  rectifier.  B. battery.  S. start. A accessories , I ?
Geo 🇺🇸
JoeM
You need a switch with a ground here is an example from a super cub I owned.
Geochurchi
Thanks! That’s what I was looking for.
Geo 🇺🇸
gwest_ca
"I" is for ignition meaning it powers an ignition coil in a battery ignition system. Wrong switch for your application.
A switch with an "M" terminal grounds the magneto to shut the ignition off. Magneto systems are self powered.
A very popular and easy to find switch
