danweikert21
Stator question
danweikert21
Hey everyone I need to replace the stator on my raider 10 model 1-0301. I’m looking for a stator I can run at least 2 led lights ( one for the front and one for the back ) do you think a 15 amp stator could handle that. And if there are bigger stators that fit on a Kohler k241s I would love to know about them. Thanks
Pullstart
You might be able to do as Stefan @Tractorhead did and wind your own…. He has some pretty detailed parts on his Bavarian Wheel Horse thread.
danweikert21
Thanks I’ll check this out
danweikert21
If a 15 amp stator would work that is fine too.
Handy Don
If you use LED lights, you could do two bright lights with 2-3 amps max.
  • Like 4
danweikert21
Meaning it would only use 2-3? My plan is to have a short led bar go in place of the original lights and then to have a small led light in the back ( just bright enough to see what I’m doing when I back up when it’s dark )
Handy Don
Yes.
For example, this light bar uses 18watts. 18w ÷ 12v = 1.5 amps. A small marker light for the rear would be about 8w (.66 amps). Together about 2.2 amps.
pfrederi
15 amps is what ran 70 watts of incandescent headlights with out a problem.  LED will not tax it at all.
  • Like 6
  • Heart 1
danweikert21
Thanks for that. Your equation really helped
  • Heart 1
pfrederi
Look up Ohms Law...
WHX??
If you have access to a DMM Dan you can easily measure the amount of current the lights use. Best practice is fuse the lights with a less than 15 amp fuse.
These lights
Drew this So I fused them all at 10 amps which is well below the 20 amp output of the tractor.
Ohm law is a great tool to have in one's tool box but I like to see it for real.  The rated wattage can be different than what the manufacturer says and actual battery voltage plays a part. Also led's are rated in an equivalent wattage which can throw a monkey wrench into calculations.
https://www.youtube.com/watch?v=HsLLq6Rm5tU
Edited by WHX??
danweikert21
Thanks for the help you guys are awesome
857lover
8 hours ago, pfrederi said:
Look up Ohms Law...
@danweikert21 if he payed attention in tech ed he would’ve known that or asked me 😂
danweikert21
I will admit I was a bit too busy goofing off :unsure:
  • Heart 1
SylvanLakeWH
The guys got you covered… led’s no problem. :handgestures-thumbupright:
BTW - Regarding not knowing or applying Ohms law, no worries… they’re letting everyone out of jail who has been convicted of violating it, and are expunging their records… you’ll be fine. :hide:
  • Haha 3
danweikert21
I wonder if there letting them out for newtons law :o
SylvanLakeWH
Yes. Especially the first one… :(
Lots if objects at rest and staying at rest…
:sleeping-yellow:
857lover
you guys are hilarious i want yo meet you all :greetings-clappingorange:
peter lena
@danweikert21  have any of these? https://www.bing.com/search?FORM=UP97DF&PC=UP97&q=smal+alligator+clip+test+wires  , its vital that you insure your GROUNDING  TO RELATED WIRING , clip from battery cable ground bolt point , with this to headlight grounding  area, that will insure function with minimum electrical draw. clean and dielectric grease every related connection , I regularly use these alligator clips for wire run testing , makes it quick simple and easy , just an idea , pete
danweikert21
I’m def gonna but a set of those clips If I’m going to run new accessories I’m gonna do it right I hate having electrical issues because of a job half way done I see that stuff all the time in the mower shop. Thanks for the idea
  • Haha 1
peter lena
@danweikert21 ,  that battery ground bolt point is a good spot to add a battery cable to the engine to frame bolt , next to clutch pedal , from there , I  go to a 10-12 ga wire  to the ignition rectifier on engine tin cooling bolt mount , increasing ground to that point , then from that to headlights  ground , tell me how that works . that enhances  total wiring grounding , easy to do , pete
