TonyI
Hydro lost pulling power
Thor27
I wouldn't think so unless you had a complete bearing failure in the mule, even then a m18 would just smoke the belt.   I'd be more inclined to agree with its being a loose engine ground, or a chaffed wire by the lever. The safety switches should only come into play when cranking.
Edited by Thor27
peter lena
@TonyI  agree with others on possible electrical connection issues . that back fire issue on deck engagement , is telling you any thing electrically related  is probably your cause. also look for chafed wiring that suddenly shows' up with engine loading . my experience is old cracked / corroded /  chaffed, shorted wires , probably is your issue. have any small alligator wire jumpers ?  used those many times to verify wire runs , backtracking , found the related shorting spot, hope you find it , pete
Lee1977
There are two switches they are stacked with insulators plastic beloe and between them. Those plastic insulators were both completely covered in rust on my 520-H that may cause a short between the two switched  when the PTO is engaged.
Both switched are bolted to a metal bracket that is fasten with one bolt.
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • bigcreek
      By bigcreek
      Price DROP!!! Horse traders out there, this great tractor is available at new price.
      99.5 hours, Horse runs like new. Really Like this horse to go to good home. Let’s talk can provide more images if needed
    • olivertractor
      By olivertractor
      I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
    • Salbreth1
      By Salbreth1
      Hello guys and thanks again for the welcome! So long story short, my wife calls me and says theirs a tractor on the trash. So like any normal human I hopped in my truck and drove up to find this 418-C and a set of aluminum ramps on the side of the road. Had to be fate.
      So me and my 6 year old sons new found love of tractor pulling has inspired this build. I’ve been researching everything about the model and currently have it stripped and prepping it for paint.
