TonyI
Hydro lost pulling power
TonyI
I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
WHX??
:WRS:
I'll call in some hydro experts.
@daveoman1966 @pfrederi
Ed Kennell
:text-welcomeconfetti: to the  :rs:Tony.     The hydro experts Jim called should be here soon to help.   Did you check for external  problems like a sheared hub or input pulley key, or a slipping drive belt ?
  • Like 6
daveoman1966
The 418-C has an Eaton hydro and I'm not at all familiar with them.
WHX??
I always forget the simple things first Ed.
Take a sharpie and draw a line across the hubs and pullies and see if the lines  move.
I have not heard of the cracking hose syndrome.
Any idea what year Tony. Just guessing it's an Eaton 1100 tranny?
Yes we have the manuals here.
Thank you Dave.
  • Excellent 1
JoeM
If it all of a sudden lost power and you checked all the things Ed mentioned it's not a wear issue more like a blown o'ring on the internal damping piston. This will allow a significant amount of oil to bypass. You say the lift is good, that says the charge pump is working and not an issue.
damping piston #43 on the drawing.
  • Excellent 2
roadapples
:WRS:
  • Thanks 1
WHX??
Thanks Joe I can't do that on a tablet and I don't think I have that one anyway. I do now! :handgestures-thumbupright:
Handy Don
If the lift is working but motion isn't then it likely is an internal issue but checking the input drive pulleys for slippage is worth checking. Good luck.
TonyI
Thank you Dave.
I believe it's and 87. no serial number on the chassis.. it's worn off, but looks good compared to the other 417A's I have. . definitely an Eaton on there.  I did just replace the fan, as the old one was all broken up, and there was a ton of grass in the compartment just under the panel.
I'll check on the hubs and pulleys.. do you have an illustration on where to mark them?
953 nut
:WRS:
My Eatom has not given me any problems but a high pitched whine is fluid bypassing like @JoeM said. The Acceleration Valves are passing a significant amount of fluid because of the "O" Ring. I have had a similar problem with the Sundstrand Hydros.
Please let us know if you dive into this problem so we can all follow along.
If your decision is to replace it with a good used unit I would suggest you call Lincoln at  https://a-ztractor.com/
  • Like 3
gwest_ca
418-C was produced only for the 1987 model year.
Ed Kennell
Just draw a line across the end of the shafts and hub.
JoeM
just another internal drawing
All the oil in the 1100 is moved via porting integral to the rotating group. Any debris, in the charge circuit, from valves, hoses, etc would get caught in the filter prior to entering the hydro for use. The design is excellent and reinforces the importance of a good quality filter.
The check valves just lay in drilled holes and really can't get out.
I put a note in the drawing if you hand push the machine and hear clicking coming from the hydro that is the acceleration valves, a good indication the springs are good.
1329200616_CaptureEaton1100pressureflowdiagramwithnotes1.JPG.bb80ef91803eb0a9df47fa24435b54b9.JPG
  • Like 4
TonyI
do the 417a and 418c have the same Eaton 1100 ?
Handy Don
Across the years, there are some minor variations in the Eaton 1100s but for practical purposes they are the same.
Understand the excessive heat is bad news for hydrostatics.  Lots of material caking it (acting as insulation) and a broken fan may have caused it to overheat and incur internal damage.
Edited by Handy Don
pfrederi
Hydro is the same there is a difference in gearing in the transaxle.  418c was fast4er than a 418a or 417a
TonyI
thanks for all the suggestions on this topic!.. I've been doing the easy stuff first.. I flushed the fluid, and marked the hubs.. no slippage there.  checking the drive belt, it was loose and cracked so I replaced it with a new 82-inch belt 5LK82, and the tractor was still loosing power going up-hill. so I put on a 5LK81 (1-in shorter belt) and it now has plenty of power.. but if I engage the PTO she'll backfire like crazy.. so not optimum.
Does anyone know the distance from the engine to the hydro or if there is a way to adjust the distance so I can get a better fit with the 82-inch belt.
Thor27
There is no real adjustment on that distance, a toro 108501 belt @ 81-1/2" "should" be the right one. When I tried an 82" it wants to rub on itself by the idler.
lynnmor
The engine mounting bolts may be loose and their holes may be elongated from wear.
The backfiring might be caused by a poor electrical connection in the PTO safety system.
953 nut
Like @lynnmor said the engine acting up sounds like an electrical problem. Remove the battery and clean the area where the PTO lever comes through to operate the PTO Safety switch. Make sure none of the connections are corroded or wires chafed. Do the same at the seat switch, a chafed wire there could be the problem.
TonyI
that 1/2-inch sounds exactly like what I need. will get a couple ordered and post an update.
TonyI
ok.. the OEM 81-1/2-inch belt did the trick.. the 418-c is now moving fwd and reverse fine. .now I need to check the PTO.   it back fires only when the deck is engaged.. and the deck turns easily by hand.   with no belt it still  stall's out.   will clean the PTO switches tomorrow.. the seat switch was already bypassed when I got the machine..  could there be something in the clutch causing too much load on the engine?
  • Similar Content
    • cyrus
      By cyrus
      1996 416-H Wheel Horse Garden Tractor
      Model # 73423
      1355 hours
      Features Electric Clutch Hydrostatic Drive Hydro Lift (mid & rear) Accessories 48" 3 blade mower deck Model #78360 Newer Blades 48" single stage High Chute Snowblower Model #79360 Side Wings for 60" cut sidth Newer Chain and Drum Sprocket 20lb Rear Wheel Horse Wheel Weights Rear Wheel Skid Chains Soft Side Snow Cab Rough but useable. Other info New Battery New Hydro Lift Cyl Hoses New Main Electrical Wire Harness Recent service (Engine Oil, Hydro Oil, Filters, and Chassis lube) Tires are in good shape with no leaks A bit cold blooded, but starts and runs great once warmed up uses no oil.
      located in Zeeland Michigan, purchased new from Westenbrook Mower in late 95. My parents are moving to a townhouse and have no further need for their trusty horse. I have my own, so off to new pastures for this one.
      Pick up only.
      8509515355704655080.mp4
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • bigcreek
      By bigcreek
      Price DROP!!! Horse traders out there, this great tractor is available at new price.
      99.5 hours, Horse runs like new. Really Like this horse to go to good home. Let’s talk can provide more images if needed
    • olivertractor
      By olivertractor
      I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
    • Salbreth1
      By Salbreth1
      Hello guys and thanks again for the welcome! So long story short, my wife calls me and says theirs a tractor on the trash. So like any normal human I hopped in my truck and drove up to find this 418-C and a set of aluminum ramps on the side of the road. Had to be fate.
      So me and my 6 year old sons new found love of tractor pulling has inspired this build. I’ve been researching everything about the model and currently have it stripped and prepping it for paint.
