peter lena 8,742 #1 Posted March 19, 2022 https://www.amazon.com/gp/product/B00175VGUA?ref=em_1p_3_im&ref_=pe_3730140_628629220&th=1 good price too, get in the habit of using in your choke and throttle runs and they work easy , add light return spring pulls on the cable ends to lever links , returning cables to end stop point , that will insure a smooth easy cable run , it works , pete 3 Share this post Link to post Share on other sites
peter lena 8,742 #2 Posted March 19, 2022 @roadapples , @oldlineman , just another experiment that makes those cables work with ease . the spring pull is on the , increase side of the lever pull , helps a lot with any setting , does not hamper any function . the setting stays where you set it , like the smooth easy function. all related movement points , especially the lever hole bracket ,typically very rusty , the spring comes back to close , as you throttle down or choke down . perforated metal spring mount points are attached to related ignition bolt mount areas. never liked the typical erratic action of the levers , and attachments, detailing their function , made them all work with ease . realize this is a area of contention , just something that I wanted to change and improve on my stuff . that super lube , makes that set up work , like it should . just me keeping it oily , pete 2 Share this post Link to post Share on other sites
