Mustang67ford
42" RD belt install issues
Mustang67ford
Trying to replace the deck belt on a 42" RD; sounds like an easy task but not quite.  The belt that was on it was not factory but seemed to fit well.  Got a 106125 OEM belt and it seems just a shy too small to lift over and around the last pulley so do I have to put the belt in the pulley groove and twist it around? The belt is not quite 89".  I didn't try forcing it on.
Edited by Mustang67ford
953 nut
Yes, that is the way to do it.            :handgestures-thumbupright:
Mustang67ford
Thanks.
Mustang67ford
Belt still won't go on.  It a genuine toro belt and tag says it is 88.88".  It is just a tad bit too small.  Might need to just go with the aftermarket belt.
76c12091520h
Pictures?
lynnmor
You do know that the one pulley is spring loaded to keep tension on the belt?  Is that pulley moving OK and does it reach the end of its travel keeping the belt from going on?  The guides and tension bar wear out, so check them.
953 nut
89" is the correct belt, I just put one on my RD deck last week. Route the belt around the center, idler and right pulley then start the belt in the groove of the left (as you would view it from the seat) and use the blade for leverage to turn the pulley while the belt works the way on.
Mustang67ford
Will get some pics.  The idler pulley is good and I am reaching the end of the travel.  With respect to needing to use the blade to twist the belt on, I didn't realize it would take that much force.  I was expecting to be able to easily twist it on by hand once the idler pulley was pushed in.  Will still post some pics before trying that.
953 nut
If the belt wasn't extremely tight it wouldn't drive the blades when cutting the lawn, the belt would just slip.
Mustang67ford
Here are the pics.
76c12091520h
Need to get that idler bar and bushings cleaned up, all that paint build up needs to go. Grab that belt, give it a turn and slip it on.
biged77
I think you have the wrong idler.  My recyler R542RC01 which looks just like yours has a 3 3/4" OD idler P/N 112425.
76c12091520h
Yes,that too, good eye!
953 nut
Your belt routing is correct. The idler being 3/4" bigger results in the belt being 1 1/3" too short. I would suggest you buy a new idler rather than a new belt so next tine you won't have to go through the same ordeal. Once you get a 3 1/2 to 3 3/4 flat idler installed all you need to do is above. You may want to put a screwdriver where your left hand is to guide the belt as the leverage of the blade works the belt on.
Edited by 953 nut
fat finger
Mustang67ford
Great, thanks guys!
Mustang67ford
Got the new idler pulley on, new belt fit.
  • Excellent 2
