Mustang67ford 234 #1 Posted March 18, 2022 Where the idler arm gos thru the holes in the F plate, seems like there should be bushings here, but the parts breakdown don't show any. Metal on metal rubbing. Has anybody drilled this out to add a brass bushing? Share this post Link to post Share on other sites
Lee1977 6,874 #2 Posted March 19, 2022 Yes I did it because mine were worn and the shaft would nock when the clutch was pushed in.. n702bill had a tread on it last week ( Adding Bronze Bushings to Frame Povit Shaft) There are pictures of mine down in the post. 2 Share this post Link to post Share on other sites
Mustang67ford 234 #3 Posted March 19, 2022 2 hours ago, Lee1977 said: Yes I did it because mine were worn and the shaft would nock when the clutch was pushed in.. n702bill had a tread on it last week ( Adding Bronze Bushings to Frame Povit Shaft) There are pictures of mine down in the post. Thanks. Will check it out. Share this post Link to post Share on other sites
oldlineman 1,487 #4 Posted March 19, 2022 I think there may have been a plastic or fiber bushing there, but I have also made this upgrade to a 1990 312H with great success. Bob 1 Share this post Link to post Share on other sites
ri702bill 8,564 #5 Posted March 19, 2022 Lee is correct - I added flanged bushings where there no bushings at all - just steel on steel from the factory. Lee took a simpler approach to do his with good results. Bill 1 Share this post Link to post Share on other sites
Mustang67ford 234 #6 Posted March 22, 2022 On 3/19/2022 at 8:41 AM, ri702bill said: Lee is correct - I added flanged bushings where there no bushings at all - just steel on steel from the factory. Lee took a simpler approach to do his with good results. Bill Was looking at your thread. That was some good machining you did there. 2 Share this post Link to post Share on other sites
