Kelly 1,030 #1 Posted June 29, 2009 Ok see if I can explain this right, I have a C-85 that I'm putting together for my son or helping him rebuild, today I pulled the hubs to swap him for the heavy duty 2 set screw hubs for single set screw hubs guess he keeps the heavy duty hubs I need 1 1/8" hubs and change the axle seals, well his tractor has 1" axles toro says 1.125" or 1 1/8" the trans was painted black before it was red so I'm thinking it came from a work horse, and I have a work horse but the model no. tag is long gone, so I can't get the part no. for the axle seals, I have the part no for my older 3 speed tractors with 1" axles is that the same? it is 1232 also want to make sure the input and brake seals are the same as the ones in the trans with the bigger axles I don't know why they won't be but...... those are input no. 100442 and brake no. 100441 Thanks Kelly Share this post Link to post Share on other sites
pfrederi 18,277 #2 Posted June 29, 2009 Kelly: The axle seals 1' (1232, CR 9815 should work.) I have found some of the older 3 speeds have a 1" brake shaft (also uses the 1232) vs the 3/4" shaft on newer ones. (100441 CR 7410) Share this post Link to post Share on other sites
