41chevy 74 #1 Posted March 17, 2022 I posted yesterday about a leaking 1 1/8” axle seal on a 1976 B 80 8 speed trans. From the reply’s it sounds like I need to split the cases and replace needle bearings due to some up and down movement with the axle. This will be my first wheel horse trans tear down. According to my owners manual I need 2, 1526 needle bearings and 2, 100443 seals, is that correct? I’d would appreciate your thoughts on anything else I may need and what to look for. Thanks Share this post Link to post Share on other sites
ebinmaine 69,711 #2 Posted March 17, 2022 Those bearings and seals are readily available in lots of different places. A great source would be our own Wheelhorse Parts and More. 1 Share this post Link to post Share on other sites
WHX?? 49,923 #3 Posted March 17, 2022 Fer sure the input & brake shaft seal and a gasket. Perhaps a new shifter boot? Get her split and some pics and we can see what else is needed. This is why we measure a block on a motor build before ordering parts. Yes Lowell will have every thing you need. You can buy his kits but he will sell just what is needed. https://wheelhorsepartsandmore.com/product-category/manual-transmissions/ 3 Share this post Link to post Share on other sites
stevasaurus 22,968 #4 Posted March 17, 2022 You should have a #5091 transmission with 1 1/8" axles. If you do have 1 1/8" axles, those numbers are correct. They cross over to KOYO B-1816 and SKF 11050. Videos of the #5091. Share this post Link to post Share on other sites
oldlineman 1,489 #5 Posted March 17, 2022 Don't worry, I did my first one last summer with great help from many folks here. I got my parts from Lowell great service. I replaced all seals and axle needle bearings. You will need a gasket for the case. My problem was broken diff. bolt so while in there did the other changes. Take your time, ask questions as they come up and you will not have a problem. Steve and others have great videos to follow. Bob 3 Share this post Link to post Share on other sites
41chevy 74 #6 Posted March 17, 2022 Thanks everyone for your help, Drained the oil and got it on the bench this afternoon, removed the 6 case bolts. I was removing the shifter lock and found it was broken and just 2 threads holding it the case. After looking at my manual I saw that it was SUPPOSE to be a set screw with a locknut. The pic shows what was in it, I tried tapping it out with a small 3 sided chisel, but no luck, I’ll be drilling in the morning. Thx again for the advice. 1 Share this post Link to post Share on other sites
ebinmaine 69,711 #7 Posted March 17, 2022 45 minutes ago, 41chevy said: set screw If I remember correctly that's a "half dog point screw". They can be had a good hardware stores or McMaster Carr. I've likely got a few. If you need one lemme know. 1 Share this post Link to post Share on other sites
lynnmor 7,479 #8 Posted March 17, 2022 If that wheel bearing is bad they can ruin the axle. Take photos of the wear surface of the bearing and seal. 1 Share this post Link to post Share on other sites
41chevy 74 #9 Posted March 17, 2022 21 minutes ago, lynnmor said: If that wheel bearing is bad they can ruin the axle. Take photos of the wear surface of the bearing and seal. Thx I’ll check out and let you know when I get it out. Share this post Link to post Share on other sites
stevasaurus 22,968 #10 Posted March 18, 2022 That dog point set screw is case hardened. Use the correct drill bet for hard metal. 2 Share this post Link to post Share on other sites
WHX?? 49,923 #11 Posted March 18, 2022 Sorry to hear about the set screw hope you have good luck in getting it out. I have some extra replacements if EB does not. 1 Share this post Link to post Share on other sites
Handy Don 13,085 #12 Posted March 18, 2022 18 hours ago, 41chevy said: Thanks everyone for your help, Drained the oil and got it on the bench this afternoon, removed the 6 case bolts. I was removing the shifter lock and found it was broken and just 2 threads holding it the case. After looking at my manual I saw that it was SUPPOSE to be a set screw with a locknut. The pic shows what was in it, I tried tapping it out with a small 3 sided chisel, but no luck, I’ll be drilling in the morning. Thx again for the advice. Stuff a rag in the shifter hole before you start so you can can and pull out any drill filings, right? Also, that screw may go in easier than out--and a rag would catch it as it emerged. Good luck! 1 Share this post Link to post Share on other sites
41chevy 74 #13 Posted March 20, 2022 On 3/17/2022 at 6:50 PM, lynnmor said: If that wheel bearing is bad they can ruin the axle. Take photos of the wear surface of the bearing and seal. Good evening, I was able to get the broken dog point screw out with a little penetrating oil, carbide drill bit and the easy out. I talked to Lincoln and he said if I didn’t want to split the cases I could drive it in and put the new one in behind it, well it wouldn’t budge so I split the cases. I got the good side out with no problem but the bad side fought me, in the process the needles came out. I ended using a small tip on my torch to run a hot line down the inside of the race and was able to drive it out then, while it was hot. The good side axle showed no wear. The other one (see pic) looks like this. The mic showed the worn part was consistently .003 smaller then the axle. I’m figuring the axle is toast, your thoughts please.thx Steve Share this post Link to post Share on other sites
lynnmor 7,479 #14 Posted March 20, 2022 I would call it toast as well. 2 Share this post Link to post Share on other sites
Handy Don 13,085 #15 Posted March 20, 2022 40 minutes ago, 41chevy said: The mic showed the worn part was consistently .003 smaller then the axle. I’m figuring the axle is toast Oh yeah. 1 Share this post Link to post Share on other sites
WHX?? 49,923 #16 Posted March 20, 2022 Really good pic on the axle guy and if this was just a show runner I would just smooth it out and call it a day. Worker best be lookin for a new axle. Good work on the tear down tho. 1 Share this post Link to post Share on other sites
41chevy 74 #17 Posted March 20, 2022 (edited) 41 minutes ago, WHX?? said: Really good pic on the axle guy and if this was just a show runner I would just smooth it out and call it a day. Worker best be lookin for a new axle. Good work on the tear down tho. Thx for the complement and for the replies. It’s not going to be a worker, although I don’t want weeping oil dripping, I replaced that seal a couple days ago and the next morning it was leaking. I think I’ll shop around for another axle. One these days when I’m gone one of the kids might want it so I want it to be right. Edited March 20, 2022 by 41chevy Missed word 3 1 Share this post Link to post Share on other sites
oldlineman 1,489 #18 Posted March 20, 2022 Yes easier to do it right now than later. Put want ad here and check with A to Z, great focks to deal with. Just a suggestion when installing new bearings I put mine in freezer overnight per suggestions from guys on here to make installing them easier. Worked great, went in with a little tapping from a small hammer and correct size socket. Bob 1 Share this post Link to post Share on other sites
stevasaurus 22,968 #19 Posted March 20, 2022 Another option for that axle...have that area spray welded and then turned down to spec. 2 Share this post Link to post Share on other sites
41chevy 74 #20 Posted March 20, 2022 1 hour ago, stevasaurus said: Another option for that axle...have that area spray welded and then turned down to spec. Thx I’m checking in my area for a weld shop. Share this post Link to post Share on other sites
41chevy 74 #21 Posted March 20, 2022 Any ideas of where to fine a used axle, 1976 B 80, 61-8k802, 5091trans, 102764, 11 5/8” Share this post Link to post Share on other sites
oldlineman 1,489 #22 Posted March 20, 2022 Put an ad here and call Lincoln at A to Z good people! Share this post Link to post Share on other sites
lynnmor 7,479 #23 Posted March 20, 2022 2 hours ago, 41chevy said: Thx I’m checking in my area for a weld shop. I would use that as a last resort, unless it is done perfectly and with the correct hardness the results won’t be good. Remember that the axle is the inner race for the bearing. 1 Share this post Link to post Share on other sites
41chevy 74 #24 Posted March 20, 2022 43 minutes ago, lynnmor said: I would use that as a last resort, unless it is done perfectly and with the correct hardness the results won’t be good. Remember that the axle is the inner race for the bearing. Thx, your right, I was surprised the axle was worn and no wear on the needles. I mic’d a few of them since they came out when I was driving it out and they show no wear, i was kind of thinking the bearing was froze up when I saw the axle wear, but I guess it wasn’t. There evidently harder than axle. I’ll call Lincoln in the morning, I’m not having much luck finding one on the internet. Thx again for the advice. Steve Share this post Link to post Share on other sites
Handy Don 13,085 #25 Posted March 20, 2022 48 minutes ago, 41chevy said: Thx, your right, I was surprised the axle was worn and no wear on the needles. I mic’d a few of them since they came out when I was driving it out and they show no wear, i was kind of thinking the bearing was froze up when I saw the axle wear, but I guess it wasn’t. There evidently harder than axle. I’ll call Lincoln in the morning, I’m not having much luck finding one on the internet. Thx again for the advice. Steve Also, if you are looking for NOS, you might try @76c12091520h, who has an eclectic and large inventory! Share this post Link to post Share on other sites
