RED-Z06 2,220 #26 Posted March 18, 2022 15 minutes ago, "Manic-Mechanic" said: I never had one pop yet, even double-checked as I stated earlier. However, your advice is taken wisely and no more grease! Really wouldn't use sealed bearings on this assembly myself, but too much grease isn't cool either...Notice the seal/spacer down into the oil seal on top, probably get pretty hot dry....Then it is only a 36" RD Deck on a Garden Tractor, not a Commercial Zero Turn. Which I use to actually mow with myself. This machine is only good for the Garden, not much good having it mow for serious... Little bit of grease is okay. But you have to remember if its not leaking out...its still in there. 1 Share this post Link to post Share on other sites
