41chevy 74 #1 Posted March 16, 2022 B 80 1 1/8” axle seal, I replaced both seals, now I see one is still leaking Axle was sanded cleaned with 400 hundred, all edges have no burrs that could possibly cut the rubber. I do notice the axle will move a 32nd up and down. Another thing the seal wont go in flush it’s a 32nd out from casting while the non leaking side is in side the casting a good 1/8. Any suggestions would be appreciated. Share this post Link to post Share on other sites
Achto 30,193 #2 Posted March 16, 2022 25 minutes ago, 41chevy said: I do notice the axle will move a 32nd up and down. Sounds like you may have a bad axle bearing. 3 1 Share this post Link to post Share on other sites
pfrederi 19,264 #3 Posted March 16, 2022 In and out movement up to about 1/8" is OK. There should be NO up/down front/rear movement... 4 Share this post Link to post Share on other sites
