ronhatch
FRONT MOUNTED FERTILIZER SPREADER?
ronhatch
With spring right around the corner here in northern Illinois, I was wondering if anyone has ever built a front mounted lawn fertilizer using a modified pull behind or walk behind unit?  The 'fertilizer slinger'  could very easily be driven by the engine PTO using a small V belt with a 1/4 twist in it.   I always thought it would be a worth while project. Unfortunately I just never got around to building one and now that I'm old and gray, it's not going to happen.
Edited by ronhatch
ri702bill
I see a swing and a miss here - you will be running over a portion of what you put down.
JCM
When I bought my first WH in 89  I also got a 36'' drop spreader for it. The only thing it seemed useful for was putting down lime and at that it made more of a mess than anything. Also tried fertilizer and was tough to make the overlap come out correct without leaving dark and light stripes on the lawn. That attachment has remained in the garage for many years idle. I resorted to a rotary walk behind spreader and never looked back. I do like your idea and hope it comes to fruition if someone could figure it out.
lynnmor
I wouldn't put a lot of effort in modifying a consumer grade spreader.  I just replaced the cracked hopper on my Agri-Fab and made a plastic bearing to fit the worn shaft, the effort and expense wasn't worth it.  These things are throw away items and are to be placed at the curb with the disposable tractors sold at the big box stores.
Handy Don
The pro landscapers around here all have stand-on powered broadcast spreaders (don't know the manufacturer). They look like chariots racing across the lawn!
The pro "weed and feed" companies are using what looks like a mini version of a farm liquid sprayer system. Even has a hose to get off and reach the spots the vehicle can't get to.
You could look at some of those for ideas!
wallfish
Is this what it looks like in  Cortlandt, New York. :ychain:
  • Haha 3
Handy Don
Yep, exactly like that except without the barrels and the ostriches! This looks like a LOT more fun. Hey, maybe substitute a WH for the ostrich and have chariot races? :hide:  🤪
Lee1977
Have you checked the price of fertilizer, after checking you may not want a spreader.
ronhatch
i  I don't see a problem with running over he fertilizer that's just been spread on the lawn Bill.
DJM; I agree with you, a drop spreader is useless for the most part, unless you have a small city lot, but I'm talking about a broadcast spreader. I should have made that clear, Sorry.
Lee, Yes the price of a 36 lb of fertilizer went up $10 at my Farm and Fleet store, but not at our local Minards store. I didn't check out our local Home Depot though.
Lynnmor; That's whats fun; Fixing and improving old stuff and making it better then new. I wish I could do that to myself!  :laughing-rofl:
ri702bill
Ron
My point is that some will get pushed into the ground, the other MAY get blown or washed away - do you really want stripes on the lawn that resemble a bad metallic paint job??
ronhatch
9 hours ago, ri702bill said:
Ron
Bill
These seem to work OK. This is the type of spreader the guys in the lawn maintenance business around here use.73476_2000x2000.jpg
