wheel horse C-175, Kohler K341 back firing at high idol
By
Josh Opitz, in Engines
Similar Content
By CHuls
*Estate Sale*
71-16KS02 1977 C Series Garden Tractor C-160 Automatic Kohler K341S-71223A 16hp Sundstrand Hydrostatic 90-1140
Comes with mower deck (not sure but, I'm told it's a 48") & 42" plow blade model/sn 42BC01 08580 7276
Been sitting for years, haven't been able to get it started. When I put a little gas in to try starting it this year, it leaked from the tank, probably cracked fuel hose
Not sure what it's all worth together but, make an offer.
By Jayzauto
I have a WheelHorse C-175-8 with Rototiller attachment. Machine is in great mechanical shape, just needs paint. Engine has been replaced with an identical Kohler KT-17 Series 1. New Carb has been installed. Battery, solenoid and cables have been replaced, starts great. Installed new Tires and Tie Rods. Installed radial bearings in spindles, so it steers beautifully. Fuel line has been changed, as well as headlights. Bew mule drive and belt fot tiller and functions as designed. I'm sure there is other items that have been done. Very reliable machine. $800/BRO
Selling all my WheelHorse items and moving South. Have other tractors ad parts if interested.
By HumbleHans
Operator manual 810343R1
Wiring
34 pages 17.5MB
Wiring Colored
1 page 228KB
By Foxer14
My grandfather is selling his C-175 and I want to buy it from him to restore it. He thinks he can get about $3000, but I think that is too high. It does come with a mower deck that is probably to rusty to use and a tiller. He says the tractor has lots of accessories on it. It will need some work as it hasn't ran in probably 15-20 years. I was thinking about $1000 but I am not sure. What do you think?
By CB520HC
hello all I figured its time to show off the horses that I own and tell a little about my Frankenhorse. My first one was the C-175 auto with original series 1 kt17 bought it for $100 "running" , driving and mowing. Little did I know that it had a broken connecting rod on the front cylinder I found this out due to going over it and checking plugs found the front plug soaked in fuel, and when I removed the piston from the jug the crank had a narly nick in it that I could see. So after crawling all over this forum I found out that my best option was to go with wither a series 2 or swap to the classic k341. Later that week I found a guy not too far away from me selling one in good shape running with starter and carb that came off either a 416-8 or a c-160 and after some custom plates and stab link bushings as vibration pads tractor was operational again and the 42" SD deck that it wears got me hooked instantly on having a horse addiction. I used this tractor to cut 6 acres of land (4 separate properties) and it did it flawlessly could not get that motor to bog at all even in the heaviest grass i could get it into, in the pictures that are attached you'll find the tractor after the swap and right after a bath but other than that i haven't changed anything other than belts and fluids about a month after this project was completed I was looking to upgrade once again to the larger 500 series and i found a 520HC with only 648 hours on the clock it also had the 60" deck that was in fantastic shape stole the tractor for $800 then right before Christmas I found a 56" snow blade chains and blower with custom rear weight bracket all for $500. So to wrap this up I have the fever and I'm hoping to add a few more in the years to come gonna be cruising marketplace this spring. Looking to add to the herd.
