RedWheelz
Raider 8 decal
RedWheelz
Belt looks pretty old.
Haven't inspected anything yet.
Now I know what to look for.
I'll peek at er' tomorrow.
ebinmaine
Keep us posted.
Remember we likes our pictures. 😀
RedWheelz
Pulleys were a bit rusty. Got them cleaned up and it didn't make much difference.
If I decide to sell it I'll probably sell as is so not sure if I wanna buy new belt or mess with it more.
ebinmaine
These pulleys are VERY rusty. The idler could be replaced. The transmission pulley can likely be shined up.
I'd say that's been setting outside or on a dirt floor unused quite some time.
RedWheelz
Yep, it was outside.
Not a big fan of outdoor, uncovered storage! All my tractors and equipment are inside, if not, they r covered.
I used a flap disk and that got them to bare metal.
RedWheelz
I put a new belt on now the idler pullry guard rubs the belt.
Is that little guard suppose to be adjustable or welded to the idler pulley arm? This one is welded.
wallfish
Is that new belt the right length? It looks short to me from the pic. A proper length belt will allow that idler pulley to go back farther which will relieve that guard from contacting the belt
A stronger spring on the other side to pull that pulley back more may solve the problem. If you can push it back by hand so it doesn't touch the belt then a stronger spring might do it. If you can't push it enough then a longer belt is the answer
Edited by wallfish
wallfish
Notice how vertical the idler arm for the pulley is in this pic below. Not as much in the recent pic
IMG_20220306_151905604.jpg.69b2e5ccadf464dc4387b42ecdcb6b38.jpg.e1a1845345fffecbd8997e94e91c7839.jpg
Edited by wallfish
Horse Newbie
I was thinking that belt “guard” is supposed to fully stop the belt when you push in the clutch …
Ed Kennell
Yes, the belt guard supports the bottom loop of the slack belt and helps to stop it from contacting the engine pulley.
If properly adjusted, that tab on the tensioner pulley will pinch  and also help to stop  the belt.
It appears your belt is too short....It should not be rubbing the belt when the clutch is engaged.
RedWheelz
The belt is 5/8 x 82" which I thought was the correct belt
Ed Kennell
That belt would probably be OK, but the tab must be adjusted so it only touches the belt when the clutch is depressed.
Horse Newbie
Yeah, that’s what I was talking about.
ebinmaine
Judging by the curve (white circle) on that side of the tab, it looks as if it's been that way for a bit.
We've had Horses like this here and had to bend/adjust/correct the issue.
I do agree with the above post(s)  about the possibility of the belt being too short.
Horse Newbie
I’m thinking it would be an 82.5” x5/8”…
you think @ebinmaine ?
Ed Kennell
I buy my belts at TSC.     When the size is questionable, I buy several sizes and return the belts That are not used for a full refund.     Just keep the belts and sleeves clean.
ebinmaine
I'm thinking it should be 81.9 x 5/8" or 5L.
I've had a few tractors that had challenges getting a belt fitted properly.
Could be a wrong size pulley.
Or belt.
This method does work. Done it.
I've switched over to using ONLY Wheelhorse/Toro belts for manual transmission tractors.
Haven't had an issue since.
Horse Newbie
Where do you get. I think I got one from Lowell…
ebinmaine
Yepp they have them.
I've gotten Horse belts off the fleabay too.
RedWheelz
Is the guard hitting to much when the clutch pedal is pressed?
Ed Kennell
    No, that looks good. The belt should stop if the belt guard is in place.
RedWheelz
So the belt that was to short was a 82" D&D belt off Amazon.
This belt is from TSC and its a Huskee Blue Kevlar.
Guess they run different.
Anyhoo, It drives ok now, just got to idle it down when taking off in 3rd gear.
ebinmaine
They just... Don't.
Belts are supposed to be standardized.
They aren't like tires that can and do vary some.
This is another example of why I went to using ONLY Wheelhorse/Toro belts.
You did perfectly fine with TSC.
Horse Newbie
Was it an 82 inch also ?
RedWheelz
Sorry yes it was a 82" , I meant to include that
And I just realized the D&D belt was 7/16 thickness and the TSC is 13/32.
Edited by RedWheelz
