Rod(NASNUT)
Help with snowblower
Rod(NASNUT)
I got my flag and lift rod made for my blower now can someone help me with mounting it on my C-105 can anyone send me pics of how these things mount?
nylyon
Don't have pics, although I can get one if you need it. Take a look at the mower lift rod, there should be either a chain or rod connecting to the lift bell crank. The bell crank is boomarang shaped with the mower connecting to the horizontal part. The snow blower flag connects to the vertical portion of the bell crank.
Now the spring, I don't have one on mine but. There should be a eye bolt in the flag, the spring connects from the eye bolt to the hole in the frame cross member.
I can get pictures, but not until much later.
nylyon
The blower itself will mount on the front tach-a-matic (removing the mule drive is it is still mounted)
Rod(NASNUT)
Whenever you can get the pics will be ok. Do the manuals show you how they mount?
nylyon
Yes, for reference you can get the manual for a 79360 that will show the spring too. Look up in the links section to get the manuals.
Rod(NASNUT)
:thumbs: Thanks for all your help nylyon I will do that. :thumbs:
