dmoore 929 #1 Posted February 26, 2022 I see a few parts being reproduced for our tractors and wondering if anyone has stepped up to faithfully reproduce complete wiring harnesses? Share this post Link to post Share on other sites
953 nut 56,740 #2 Posted February 26, 2022 (edited) The wiring harnesses on Wheel Horses underwent numerous changes over the years and even had some midyear changes during the year. No one has or is likely to offer reproduction wiring. You can do your own rewiring with a few simple tools and the wiring diagram for your particular tractor. What model are you working on? We can help you along where needed. Dell City is a great source for the parts, wire and tools you will need. They supply good quality connectors in a variety of configurations. https://www.delcity.net/?mkwid=s&crid=532441923049&mp_kw=dell city electronics&mp_mt=e&gclid=CjwKCAiAvOeQBhBkEiwAxutUVLW4d80ysIq5OnU0rcpstxbgFWNjTRsxK5sSpiClJHJTsqRH4NjBPBoCQdEQAvD_BwE Edited February 26, 2022 by 953 nut fat finger 4 1 2 Share this post Link to post Share on other sites
rmaynard 15,799 #3 Posted February 26, 2022 Early tractor harnesses were very simple and easy for just about anyone to reproduce. But as the tractors became more complicated, so too did their harnesses. If you go to any online Toro parts supplier and find a part number for any wiring harness, clicking on it will show that it is only compatible with a particular model/year. As @953 nut pointed out, mid-year product changes made wiring unique. I don't think that anyone would be able to make all types of harnesses and still be able to make money unless they sold their product for a lot more than the average buyer would be willing to pay. 6 Share this post Link to post Share on other sites
peter lena 8,970 #4 Posted February 26, 2022 @dmoore , why not contact a wire make up specialist ? all over the net , tell them what you have and what you want , eliminate the problems , https://www.speedwaymotors.com/info/helpcenter , all of these guys have lay out walls , with wiring schematics , that over lay problem areas . just an idea , seen some of their work , plug in solid reliability . hunt around , make a change for the better , pete 1 Share this post Link to post Share on other sites
dmoore 929 #5 Posted February 26, 2022 Going idea Pete, I have a guy who I have used for years for replacement wiring harnesses on my old cars.👍 1 Share this post Link to post Share on other sites
peter lena 8,970 #6 Posted February 26, 2022 @dmoore think its just the way to go , have a similar friend thats really sharp on wiring problem change outs . easily helped out with chronic horse wire set up . also do some rerouting to eliminate chafing and tight bend areas , use cable wrap to protect your work . why not make it solid and reliable ? good luck with it , pete 1 Share this post Link to post Share on other sites
mike avad 41 #7 Posted February 15, 2023 I have a 1988or 89 252-H wheel horse am just get ready to try to duplicite my wire harness all same color code. this will be my first i'v done order the male and female end's for the plug's also. I'V loo up and down try to find one for my tractor new no luck. 1 Share this post Link to post Share on other sites
peter lena 8,970 #8 Posted February 15, 2023 @mike avad whatever you do , don,t be afraid to REROUTE AND ELIMINATE TIGHT BINDING AREAS , cable wrap , enhance battery ground bolt point , to your cable grounding , directly , add mechanical electrical lugs. insuring ground as you go . pete 1 Share this post Link to post Share on other sites
peter lena 8,970 #9 Posted February 15, 2023 @mike avad https://www.bing.com/shop?q=electrical+mechanical+lugs&FORM=SHOPPA&originIGUID=D1B1265B383A4258BF14AB00AFCEBE95 this the type of lug you want , contractor section , always giving you a solid easy go to connection point .pete Share this post Link to post Share on other sites
