RonnieB2nd
520H Onan Attachment options
RonnieB2nd
Will Universal plows or harrowing disck plates work on these tractors. I haven't had much time to explore my new 520h. To be honest I thought it had a starting problem after I bought it. So life goes on.  I try again and she fired right up.  I totally forgot the damn throttle lever down around My knee.  I was using the choke lever only. Laugh it's funny and sad lol. Now she runs like a scalded dog.
stevasaurus
There is a "Chart Attachment Interchange" pinned at the top of this section, that will get you started with what attachments work on the 529H.  Others will have to chime in, that have 520H's, to offer their knowledge on "Universal" implements.  :eusa-think:
sergeant
Any sleeve Hitch Implement will work with the 520H as Long as You Have a Clevis Hitch on the Tractor which can be found here https://wheelhorsepartsandmore.com/product-category/hitches/
Plus You will need this https://wheelhorsepartsandmore.com/product/toro-wheel-horse-rock-shaft-kit-for-hydro-transmission-with-tube-bracket-long-clevis-read-description/ if not on tractor already
Everything on this Page https://brinly.com/product-category/ground-engaging/  will work on the 520H except for Front Dozer Blade
Every attachments on this Page http://www.agri-fab.com/Products/Ground-Engaging.aspx will work with your 520H
And Many of these attachments https://www.motoalliance.com/all-products/impact-implements/pro-implements will work as well as Long as You Invest In this https://www.motoalliance.com/pro-sleeve-hitch
:handgestures-thumbupright:
