Similar Content
By Mr guisepp
Wheel Horse Raider 8
model 1 0330 7
see photo
replaced side main drive belt with manufactures proper belt...( old one broke) belt installed properly...correct size...refuses to brake.
Looking for what I think is a drum brake
( see photo)
anyone have?
Am I right in thinking this could be braking problem? If it's wore out?
located at left rear wheel.
Desperate to solve this braking problem.
By JasonMc
Hi guys, I purchased my firs WH - a 1976 C-120 Automatic. I have a steep hill on my property and before I go down the hill, I want to understand how my braking system works. I’m aware that this year/model didn’t include disc brakes, so is the breaking purely hydraulic Via transmission and controlled by the speed lever? Has anyone encountered issues with this? Is it safe to use on a steep hill? Any input is greatly appreciated. Thanks!
Jason
By Chuck14025
C120, 1974/75
I added braces and shims to the rear end of the frame to beef up the cracked existing 'frame to transmission bracket'. Now, the parking brake does not engage.
The shims are about 1/8" and have to stay on.
Is there a way to adjust the parking brake?
By WheelE
Hi All, (what's the proper term for Wheel Horse aficionados? Wheelies? Horsers? Whiskey Hotels?),
Just became proud owner of a 1970 Charger 12 Auto with tiller and hydraulic loader. We've decided to call it Samwise because it's small but mighty and (we hope) dependable.
I'm still figuring things out and have one issue: the parking brake lever keeps popping up on its own. That doesn't stop the tractor, so I assume the pawl has been ground down / busted. And, the transmission continues to get power with the lever up, which makes me think someone has installed a drive belt that is too short. Does that seem likely? What is the proper size belt?
Thanks! I'm sure I'll have many more questions. I've already learned a ton perusing the archives.
By Al C.
For years I have been struggling with the brake on my Wheel Horse 1067. Forward motion down hill takes left leg full force to stop and reverse motion down hill is impossible to stop. So I did a little research and ended up buying a new brake lining from RMaynard (Bob) here on Red Square. Instructions with it are simple and they work. Put the brake shoe and new lining on this morning (used Goop to attach the lining to the shoe). What a difference! Stops on a dime, on a hill, forward and reverse. Thanks, Bob !!
