earlleecliffton 38 #1 Posted February 21, 2022 My lift Handel doesn't want too stay latched up sometimes, any ideas? Share this post Link to post Share on other sites
Ed Kennell 38,043 #2 Posted February 21, 2022 Try spraying some PB Blaster in the top end around the push button. 4 Share this post Link to post Share on other sites
SylvanLakeWH 25,502 #3 Posted February 21, 2022 (edited) In addition, have you checked underneath to determine if your chain / bar etc. are adjusted correctly and not binding? Connecting points are not the same for all implements… Also check the adjustment knob for correct adjustment for the implement you are using… Edited February 21, 2022 by SylvanLakeWH Share this post Link to post Share on other sites
earlleecliffton 38 #4 Posted February 22, 2022 Thanks I was thinking weak spring Share this post Link to post Share on other sites
Lee1977 6,648 #5 Posted February 22, 2022 (edited) If you are still using the lift bar they can get bent a hang up. I have changed my C-120 to the later chain type. Edited February 22, 2022 by Lee1977 1 Share this post Link to post Share on other sites
oliver2-44 9,710 #6 Posted February 22, 2022 If you need to replace your lift handle spring , here's a thread about doing that. Share this post Link to post Share on other sites
peter lena 8,588 #7 Posted February 22, 2022 @earlleecliffton , agree with @edkennell, on the lubricant , should get some rust run out , also look at any related rusty linkage related areas . pete Share this post Link to post Share on other sites
