TJ5208
520-8
TJ5208
Okay guys my transmission just went out on my 520-8 it won't pull itself and when you go to push  the tractor by hand while it is in gear it just makes a grinding noise what could cause this.
Edited by TJ Salyers
TJ5208
Ok figured out the problem it was in the center of the hi and low range.
TJ5208
But the tractor still won't shift right anytime what can cause that.
Pullstart
Have you checked the fluid level?
Achto
I didn't think that it ran right now.:confusion-confused: Is this thing self destructing all by its self??
When they are not running you sometimes have to rock them a little to line the gears up so that they will mesh correctly. Just the nature of a standard tranny.
SylvanLakeWH
:text-yeahthat: x2…
And gently try to shift those gears… force is not your friend in this case…
lynnmor
You cannot shift while in motion, if that is what you are doing.
TJ5208
The fluid level is at full. I never shift while in motion. And a lot of times what I do from the when I read the manual is I push the clutch in and put it back out and try it again and it works.
pfrederi
That is what you have to do sometimes with straight cut gears and no synchronizers.
gwest_ca
Do you have the belt guard on? It must be there to support the belt when it is loose.
TJ5208
Yes it does have a belt guard since it's now running right it hasn't had any more problem shifting thank you guys.
