TJ5208 1,824 #1 Posted February 20, 2022 (edited) Okay guys my transmission just went out on my 520-8 it won't pull itself and when you go to push the tractor by hand while it is in gear it just makes a grinding noise what could cause this. Edited February 20, 2022 by TJ Salyers Share this post Link to post Share on other sites
TJ5208 1,824 #2 Posted February 20, 2022 Ok figured out the problem it was in the center of the hi and low range. 1 Share this post Link to post Share on other sites
TJ5208 1,824 #3 Posted February 20, 2022 But the tractor still won't shift right anytime what can cause that. Share this post Link to post Share on other sites
Pullstart 63,090 #4 Posted February 20, 2022 Have you checked the fluid level? 1 Share this post Link to post Share on other sites
Achto 27,750 #5 Posted February 20, 2022 1 hour ago, TJ Salyers said: But the tractor still won't shift right anytime what can cause that. I didn't think that it ran right now. Is this thing self destructing all by its self?? When they are not running you sometimes have to rock them a little to line the gears up so that they will mesh correctly. Just the nature of a standard tranny. 3 Share this post Link to post Share on other sites
SylvanLakeWH 25,916 #6 Posted February 20, 2022 57 minutes ago, Pullstart said: Have you checked the fluid level? 4 minutes ago, Achto said: I didn't think that it ran right now. Is this thing self destructing all by its self?? When they are not running you sometimes have to rock them a little to line the gears up so that they will mesh correctly. Just the nature of a standard tranny. x2… And gently try to shift those gears… force is not your friend in this case… 1 Share this post Link to post Share on other sites
lynnmor 7,352 #7 Posted February 21, 2022 1 hour ago, TJ Salyers said: But the tractor still won't shift right anytime what can cause that. You cannot shift while in motion, if that is what you are doing. Share this post Link to post Share on other sites
TJ5208 1,824 #8 Posted February 21, 2022 14 hours ago, Pullstart said: Have you checked the fluid level? The fluid level is at full. I never shift while in motion. And a lot of times what I do from the when I read the manual is I push the clutch in and put it back out and try it again and it works. 1 Share this post Link to post Share on other sites
pfrederi 17,865 #9 Posted February 21, 2022 1 hour ago, TJ Salyers said: The fluid level is at full. I never shift while in motion. And a lot of times what I do from the when I read the manual is I push the clutch in and put it back out and try it again and it works. That is what you have to do sometimes with straight cut gears and no synchronizers. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,090 #10 Posted February 21, 2022 17 hours ago, TJ Salyers said: But the tractor still won't shift right anytime what can cause that. Do you have the belt guard on? It must be there to support the belt when it is loose. Share this post Link to post Share on other sites
TJ5208 1,824 #11 Posted February 21, 2022 Yes it does have a belt guard since it's now running right it hasn't had any more problem shifting thank you guys. 1 Share this post Link to post Share on other sites
