Pullstart 62,193 #151 Posted June 2, 2022 19 minutes ago, squonk said: This is my favorite implement to display at shows. Then why sell it? Seems like getting rid of all your 10mm’s and 9/16’s… handy tool to keep 1 Share this post Link to post Share on other sites
squonk 40,739 #152 Posted June 2, 2022 (edited) 25 minutes ago, Pullstart said: Then why sell it? Seems like getting rid of all your 10mm’s and 9/16’s… handy tool to keep I have lived in this house since 1988. Power has gone out for like a total of about 5 hours. ( I know tempting fate) It comes out for the Steam Pageant for 3 days. Collecting dust. It's just time and I can use the cash. Edited June 2, 2022 by squonk 3 Share this post Link to post Share on other sites
Ed Kennell 37,491 #153 Posted June 2, 2022 39 minutes ago, squonk said: Collecting dust Same here. I have an Onan powered genset I should probably put on the market. 2 Share this post Link to post Share on other sites
SylvanLakeWH 25,162 #154 Posted June 2, 2022 2 hours ago, squonk said: Collecting dust. Careful now… that’s a perfectly reasonable use and explanation for any Wheel Horse tractors, parts, implements or related stuff… 1 2 Share this post Link to post Share on other sites
Pullstart 62,193 #155 Posted June 2, 2022 48” Toro Wheelhorse snow plow with 520 Extension Kit. Asking $300 The extension kit alone is over $170 new… 3 Share this post Link to post Share on other sites
Lane Ranger 10,853 #156 Posted June 2, 2022 I will have some 1 inch dogpoint set screws with lock nuts for sale at the Big Show. These longer set screws make it much easier to get on and off your shifter on your manual transmissions on your Wheel Horse tractors. $2 at the Big Show just look or ask for Lane Ralph. 4 Share this post Link to post Share on other sites
RJ Hamner 1,007 #157 Posted June 2, 2022 14 minutes ago, Lane Ranger said: I will have some 1 inch dogpoint set screws with lock nuts for sale at the Big Show. These longer set screws make it much easier to get on and off your shifter on your manual transmissions on your Wheel Horse tractors. $2 at the Big Show just look or ask for Lane Ralph. Put me down for 2. So our total is now $34 1 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,237 #158 Posted June 2, 2022 @Lane RangerI'll take 2 , I'll find you at the show unless the squonk acts up when I show up. 1 Share this post Link to post Share on other sites
squonk 40,739 #159 Posted June 2, 2022 (edited) 65 1075. This was my Covid project. Runs excellent. Hydro is strong. New battery, throttle ,lift cables, drive belt and tensioner pulley. NOS tires all the way around. Seat cover by Bob Ellison has a tiny tear on the upper left corner. $695.00 I have the bigger wheels/tires and the front tires that were on it that I can swap out and sell the tractor for less if someone wants it that way. I will not bring to the show unless someone is serious about buying it. SOLD!!! Edited June 13, 2022 by squonk 2 Share this post Link to post Share on other sites
stevebo-(Moderator) 8,264 #160 Posted June 2, 2022 3 hours ago, Lane Ranger said: I will have some 1 inch dogpoint set screws with lock nuts for sale at the Big Show. These longer set screws make it much easier to get on and off your shifter on your manual transmissions on your Wheel Horse tractors. $2 at the Big Show just look or ask for Lane Ralph. Lane- -Put me down for 5 please!! 1 Share this post Link to post Share on other sites
squonk 40,739 #161 Posted June 2, 2022 @Lane Ranger You should have order'd more! 3 Share this post Link to post Share on other sites
Lane Ranger 10,853 #162 Posted June 2, 2022 2 hours ago, squonk said: @Lane Ranger You should have order'd more! i did ! 1 1 Share this post Link to post Share on other sites
953 nut 54,374 #163 Posted June 3, 2022 18 hours ago, Lane Ranger said: $2 at the Big Show just look or ask for Lane Ralph. Just look for this banner at Lane's tent. 1 7 Share this post Link to post Share on other sites
Lane Ranger 10,853 #164 Posted June 3, 2022 (edited) A heavy Wheel Horse garden plow! 10 or 12 depending on where you measure moldboard or plow face. Can bring to Big Show if interested in buying this. This is for heavier Wheel Horse tractors with 10 hp or more motors like 953/1054 or others with a slot hitch. $175 Not bringing this to the Big Show!!! Edited June 21, 2022 by Lane Ranger 2 Share this post Link to post Share on other sites
76c12091520h 3,587 #165 Posted June 3, 2022 Round seat pan, not genuine Wheel Horse but clean, solid, and will fit. $25.00 1 Share this post Link to post Share on other sites
Lane Ranger 10,853 #166 Posted June 4, 2022 (edited) I will have some #2767 replacement gaskets for Wheel Horse tractors with the Tecumseh gas tank neck protruding from the hood. These include Lawn Rangers, and several other pre 1970 model round hood tractors. $4 per gasket at the Big Show. Edited June 4, 2022 by Lane Ranger Share this post Link to post Share on other sites
Handy Don 11,887 #167 Posted June 4, 2022 2 hours ago, Lane Ranger said: some #2767 replacement gaskets for Wheel Horse tractors with the Tecumseh gas tank neck protruding from the hood I'll be comin' by for one! 1 Share this post Link to post Share on other sites
fast88pu 3,324 #168 Posted June 5, 2022 Looking for a nut roaster roller. No engine and junk tires is fine. What's for sale ? Thanks Share this post Link to post Share on other sites
76c12091520h 3,587 #169 Posted June 5, 2022 Fully rebuilt K321S / 14 HP Kohler, completely done from air cleaner to oil pan. Stock bore, new piston, rings, rod, gaskets, seals, balance gears removed, valves properly reground. Every single replacement part is a genuine Kohler piece, even the oil. Carb was completely cleaned and rebuilt with new gaskets, needle, seat , and brass float. Has been bench run and is ready to install. Professionally refinished using PPG catalyzed "Hot Rod Black" (no spray can resto) $800.00 2 5 2 Share this post Link to post Share on other sites
Sparky-(Admin) 21,078 #170 Posted June 5, 2022 Couple items for sale. I arrive Friday morning around 10:30 and stay till the raffle is over on Saturday (not there on Thursday) SOLD 1/ Real deal high back Wheel Horse seat with the WH emblem. Not a single rip or tear. All 4 bolts thread in nice like they should and I put a dap of grease on each one when I sank em back in for storage a year ago. Seat pan is solid but could use a touch up with black paint if it was going on a show rig. Bring a 1/2” wrench and bolt it right on your machine at the show and be the envy of all your friends ! Brought to the show for $100. (Firm price) SOLD 2/ Pair of 6-12 GoodYear Super-Sure-Grip Ag tires on nice rims. Pulled from the shed after sitting there for over 2 years and still had air in em! Not tubed and not filled with anything caustic like calcium so the rims are in great shape. Tires have dry cracking like all old tires, but have lots of thread left. Bolt on and go farming ! Delivered to the show for $40 ( Firm price) 1 1 Share this post Link to post Share on other sites
Pullstart 62,193 #171 Posted June 5, 2022 @Sparky I’ll take those ags please! 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,078 #172 Posted June 5, 2022 12 minutes ago, Pullstart said: @Sparky I’ll take those ags please! Thanks Kevin…Sold! 1 Share this post Link to post Share on other sites
Darrenw85 604 #173 Posted June 5, 2022 I'll take the seat @sparky. Thanks, Darren 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,078 #174 Posted June 5, 2022 4 minutes ago, Darrenw85 said: I'll take the seat @sparky. Thanks, Darren Great, thanks…Sold! Share this post Link to post Share on other sites
Docwheelhorse 2,647 #175 Posted June 6, 2022 On 2/15/2022 at 1:24 PM, rjg854 said: I'm on the lookout for a 54" dozer blade. HI, you going to the show? I have 1 or maybe 2 54" blades off of 1054's / GT14's... maybe the frames too, I'm not sure PM me your cell and maybe we can work a deal... I'll text pics of what I have Tony 1 Share this post Link to post Share on other sites
