TJ5208
Brake band
TJ5208
Ok guys when I went to pick this tractor up it had no brake well I tightened the brake band down still making no difference just rolls. I tightened the nut on the brake band it seemed to help a little. Now the brake band is dragging. What do I need to tighten? Or is the brake band or drum wore out? I tried to push the tractor no skidding. Just rolling. And the nut on the brake band is at the end of threads won't tighten no more
Edited by TJ Salyers
Achto
Is there any pad left on the brake band? Can you get a picture from the side?
TJ5208
Just give me a sec I'll go get one.
TJ5208
Here you go.
Achto
Looks like there is pad yet. Set the parking brake and try pushing the tractor. Watch the brake hub and see if it is tuning. If it's not turning but the tractor moves, then you may have a sheared key on the brake hub.
TJ5208
The brake hub turns.
TJ5208
I set the parking brake our driveway has a little incline I start the tractor and it rolls down the driveway.
  • Sad 1
Achto
Is the band opening and closing with the brake peddle?
TJ5208
Yes the band seem to tighten on the drum.
TJ5208
But the tractor won't stop.
Achto
Seems to be operating correctly. The pad may be warn down too far for the stock adjustments. Remove the adjustment nut and place a larger nut on that will slide over the rod. Put the original adjuster nut on and adjust it again. The larger nut will just be there to take up some space.
  • Like 4
TJ5208
Could I leave that nut there if it stopped the tractor. I don't think I could or should just gonna listen to you guys.
953 nut
Get a new brake lining from Bob, they work a lot better than the ones that came with the tractor.
@rmay
  • Like 5
TJ5208
None of us here have a PayPal account.
Achto
Yes, the nut will be used as a spacer. The original nut will not thread on any further. Right? Put a larger nut in front of it as a spacer.
TJ5208
My neighbor has a part 416-8 so I guess I'll see if I can get the brake band off that and see if it works.
TJ5208
Just didn't know if it's going to hurt anything.
TJ5208
But what does it mean when the brake band is dragging the drum.
Achto
Will be just fine. Just know that some where down the line you will want to get a new brake lining. It's a temporary fix that will buy you a lot of time.
lynnmor
Did you follow the instructions in the owners manual?
rmaynard
PM me
I can give you alternate payment methods
Edited by rmaynard
  • Excellent 3
TJ5208
Yessir tighten it till it skids then tighten it 1/2 turn. But still won't stop.
rmaynard
I don't think I saw whether this is a manual or hydro. If it's hydro and you are not returning to the neutral position, it won't stop. Manual is different.
TJ5208
It's a 520-8
