formariz 11,993 #1 Posted February 7, 2022 (edited) Also pretty much totally forgotten today, is the Carpenters Hatchet. Built unlike other hatchets it features the obvious hammer end. It is however the edge end that makes it an incredibly efficient tool. It is much thinner in section and usually beautifully balanced. It is also handled differently since it is used in a different manner usually choking it or even handling the blade. Essentially it is more of an adze than a hatchet and used as such. Here it is used many times as a combination carving tool and draw knife. It is kept razor sharp. I have a different bevel on each side since I am right handed and use it on much as stated before. It is an elegant tool that is very useful in all aspects of carpentry. There was a time when it was a common tool in a carpenters tool box. Today of course most have never even seen one much less use them. Elegant and light Designed to fit one’s hand upfront Thin well balanced head Well tempered edge like a good chisel Will take a razor edge and keep it works like an adze can be used like a carving tool or drawknife one of my favorite tools Edited February 7, 2022 by formariz 1 5 4 Share this post Link to post Share on other sites
WHNJ701 4,165 #2 Posted February 7, 2022 My wife's grandfather's, we called them shingle hammers. 5 1 Share this post Link to post Share on other sites
formariz 11,993 #3 Posted February 7, 2022 On 2/7/2022 at 8:44 PM, jabelman said: My wife's grandfather's, we called them shingle hammers. Yes, similar but a usually a little different in cross section. Usually a heavier blade not tapering so much. As time went on newer models became substantially different losing some of the earlier features that had made them so useful for some of the originally intended tasks. Like everything else . 1 Share this post Link to post Share on other sites
WHNJ701 4,165 #4 Posted February 7, 2022 They do come in handy, there's a few others in the garden sheds Share this post Link to post Share on other sites
OutdoorEnvy 1,733 #5 Posted February 7, 2022 That is an awesome carpenter's hatchet farmariz! You have it in tip top shape too! I love old hand tools! Don't get me started on them...but here is a nice Plumb carpenter's head I need to get a handle for soon. It was pretty dirty but cleaned up nice and looks hardly used! It is sharp and ready for a handle! Used to you could get wooden handles at the hardware store for about anything, now you have to order most of them. The head in the pic is on my C-100 project tractor so technically fits in with the forum here 3 1 Share this post Link to post Share on other sites
midpack 967 #6 Posted February 7, 2022 I just used one yesterday... to chop a channel in ice to drain water... lol I DID carefully dry and oil it afterward! 1 1 Share this post Link to post Share on other sites
formariz 11,993 #7 Posted February 7, 2022 @jabelman@OutdoorEnvy, Good to see others using them. It’s a great tool. It’s one of my favorite tools. Love making long chamfers and Lamb’s tongues with them. The handles are easy to make. Not as contoured as a usual hatchet since it is used differently. Share this post Link to post Share on other sites
formariz 11,993 #8 Posted February 7, 2022 You can see the difference here from the early original versions. Much thicker cross section . By then mostly roofers used them and split shingles by striking shingle on face amongst other uses. Early versions are much more like an adze blade having less than half of the weight. The newer version is too heavy in cross section to be used like that. 2 Share this post Link to post Share on other sites
OutdoorEnvy 1,733 #9 Posted February 7, 2022 So what's the head weight on yours @formariz? is it 1lb or under? Mine is 1.5lbs and isn't as slim profiled as yours. Profile on yours looks great though...maybe you should send me yours and after a few years of use I'll have my own opinion Share this post Link to post Share on other sites
stevasaurus 23,045 #10 Posted February 7, 2022 I knew I had one of those. Shows more use then Cas's. I think it was my Grandfathers. Has Collins & CO on the blade. 2 Share this post Link to post Share on other sites
Southern_Secret 463 #11 Posted February 7, 2022 I'v always called them a framing hatchet, but that's all I use when building structures. It has not and never will be forgotten around my homestead. 1 Share this post Link to post Share on other sites
formariz 11,993 #12 Posted February 7, 2022 On 2/7/2022 at 9:54 PM, OutdoorEnvy said: So what's the head weight on yours @formariz? is it 1lb or under? Mine is 1.5lbs and isn't as slim profiled as yours. Profile on yours looks great though...maybe you should send me yours and after a few years of use I'll have my own opinion One pound including handle. Haha, This one will never leave here. It’s been loved and well used all of its life. It’s actually very hard to find one like this . Got to always hide it when grandchildren are here. An accident with it will not be minor. Even I have to be careful with it. 3 Share this post Link to post Share on other sites
formariz 11,993 #13 Posted February 7, 2022 On 2/7/2022 at 10:01 PM, stevasaurus said: I knew I had one of those. Shows more use then Cas's. I think it was my Grandfathers. Has Collins & CO on the blade. WOW. I actually never seen one worn to the nail slot like that. That guy really worked a lot. 1 Share this post Link to post Share on other sites
formariz 11,993 #14 Posted February 7, 2022 On 2/7/2022 at 10:03 PM, Southern_Secret said: I'v always called them a framing hatchet, but that's all I use when building structures. It has not and never will be forgotten around my homestead. Everyone calls them something different depending on its main use, but they all are Carpenters hatchets . If one does any timber framing it is indispensable from adjusting tenons , making pegs, running chamfers, lambs tongues etc, etc. it can take the place of several other tools . 1 1 Share this post Link to post Share on other sites
stevasaurus 23,045 #15 Posted February 7, 2022 Cas, I just noticed mine and yours have the same regular hammer head, not like the others shown. Mine is also thinner then the others, but not quite as thin as yours. It is also really sharp, even with some minor nicks in the blade. Share this post Link to post Share on other sites
Pullstart 64,398 #16 Posted February 7, 2022 I’ve got one of those. I’ve never realized what it’s design is for! Share this post Link to post Share on other sites
formariz 11,993 #17 Posted February 7, 2022 On 2/7/2022 at 10:31 PM, stevasaurus said: Cas, I just noticed mine and yours have the same regular hammer head, not like the others shown. Mine is also thinner then the others, but not quite as thin as yours. It is also really sharp, even with some minor nicks in the blade. Older ones will have the hammer head shape like that and of course be thinner. Later they became heavier with a thick cross section . The nice smooth shapes like where to rest ones finger became less pronounced. A lot easier to produce and as times went on the usage changed. 2 Share this post Link to post Share on other sites
formariz 11,993 #18 Posted February 7, 2022 On 2/7/2022 at 10:56 PM, Pullstart said: I’ve got one of those. I’ve never realized what it’s design is for! Great to see them all coming out now. Keep it out and use it. Handiest of tools. Even when splitting wood it is good to have on hand to separate stubborn stringy pieces like when splitting elm. 2 Share this post Link to post Share on other sites
Pullstart 64,398 #19 Posted February 7, 2022 I do know that I need a new handle on it. It has about umpteen nails as wedges, maybe some screws, other wooden wedges, etc… and it’s still loose! I kept it in the basement at the old house, next to the wood stove for splitting little kindling. It’s nowhere near razor sharp! Share this post Link to post Share on other sites
formariz 11,993 #20 Posted February 8, 2022 On 2/7/2022 at 11:31 PM, Pullstart said: I do know that I need a new handle on it. It has about umpteen nails as wedges, maybe some screws, other wooden wedges, etc… and it’s still loose! I kept it in the basement at the old house, next to the wood stove for splitting little kindling. It’s nowhere near razor sharp! Properly making but more importantly installing a handle on a tool so it stays for the life of tool is also sort of a lost art. Lots to know and understand in that subject. Fitting and correct wedging are critical. If done correctly should never get loose. The looseness is also created many times through negligence and improper use of tool. Additional wedges, nails and submerging in water are all mistakes that will just prolong the misery of using a tool in that condition. It is altogether dangerous. After fitting a handle I always melt wax onto end sealing it. Perhaps I’ll do a “making and fitting handles thread?” 3 1 1 Share this post Link to post Share on other sites
Kenneth R Cluley 582 #21 Posted February 8, 2022 I've got my Grandfather's on my bench right now. Use it all the time and consider myself lucky to have it. Think of him every time I use it. 1 Share this post Link to post Share on other sites
Skwerl58 743 #22 Posted February 8, 2022 Great tool! Dad gave me his last year and I had to redo the handle after years of use. I took the handle out and trimmed it up and reinstalled it. Fits great just little shorter. I get my new handles from a company by the name of House Handle that produces handles for about anything. Good quality and price. Share this post Link to post Share on other sites
WHNJ701 4,165 #23 Posted February 8, 2022 There is or used to be a dude on eBay that sold odd ball unfinished hickory handles. I think he has business that makes nice ones but he was selling the "seconds" handles in lots of 5, 10 etc... , He would send a mix of different sizes. Cheap too. I bought a bunch to fix up the various heads I picked up. Share this post Link to post Share on other sites
SylvanLakeWH 27,307 #24 Posted February 8, 2022 (edited) On 2/8/2022 at 12:09 AM, formariz said: Perhaps I’ll do a “making and fitting handles thread?” I for one would appreciate that. Periodic issue with Dad’s and Grandpa’s old tools… Edited February 8, 2022 by SylvanLakeWH 3 Share this post Link to post Share on other sites
tunahead72 2,515 #25 Posted February 8, 2022 On 2/8/2022 at 12:09 AM, formariz said: ... Perhaps I’ll do a “making and fitting handles thread?” ... Yes, please! Share this post Link to post Share on other sites
