TJ5208
Not running right
TJ5208
Just now, Snoopy11 said:
vwater
Hmm.      Had to do it
Edited by TJ Salyers
  • Haha 1
TJ5208
Would washers work to?
Snoopy11
I also recommend...
Buy Libman Heavy-Duty Scrub Brush
Which is what I have/use... works awesome...
Don
TJ5208
I also recommend...
Don
How am I supposed to get my hand or that in the tank.
ebinmaine
13 minutes ago, Snoopy11 said:
ebinmaine uses BBT's bathtub
This here Maine Bear 🐻 does NOT feel that's in his best interest.
  • Haha 2
wallfish
Hot cold whatever. Gasoline and the junk in there won't care because it isn't the white clothes
Anything that fits in the hole will work but remember, you gotta shake'm all out of the hole too.
Nut and bolts have sharper edges than washers do but use whatever you got. Rocks work.
Simple Green or other cleaners like that will work too
Snoopy11
I figured as much... :laughing-rolling:
Through... the... fuel... cap... filler... hole... :eusa-think:
How big is the hole where you put fuel in? :scratchead:
Don
RED-Z06
12 minutes ago, TJ Salyers said:
Why'd you leave it sitting outside again.
Previous owner parked it about 16 years before i got it, tires were rotted off, wheels partly rusted away, deck was about 40% dissolved...engine stuck, nothing at all moved or worked
TJ5208
Don
pacer
HOT vwater if at all possible. :handgestures-thumbupright:
With some type of detergent, if there was ANY oil substance in there youll want something to break it up ---- Dawn dish, Purple power, etc, then do the heavy rinsing/drying.
Snoopy11
Just now, TJ Salyers said:
Oh... well... that speaks for itself.
IN DAT CASE... you would need... something like this...
3 pc TUBE CLEANING WIRE BRUSHES STAINLESS STEEL BRUSH PIPE ...
Don
Snoopy11
6 minutes ago, pacer said:
Dawn
:text-yeahthat: :banana-dance:
Don
TJ5208
Don
Snoopy11
Palmolive... :huh:
FINE... whatever... :rolleyes:
:laughing-rolling:
Don
TJ5208
Palmolive... :huh:
:laughing-rolling:
Don
It's the only thing we have right now.
Snoopy11
It's only thing we have right now.
I'm just poking you, bud. :teasing-poke:
Don
Jeff-C175
Palmolive
Madge says, "You're soaking in it!"
  • Haha 3
wallfish
4 minutes ago, TJ Salyers said:
@AMC RULES Craig is gonna LUV you
  • Haha 1
TJ5208
Don
Well dadgum it was supposed to be a joke.
TJ5208
So here's the plan take the Palmolive and get some hot water but in the tank put a bunch of washers or whatever I can find in the tank and shake it like the world's going to end.
  • Excellent 2
Snoopy11
joke
Yeah... @Jeff-C175 and I... are 2 of the biggest :occasion-clown:'s on the site when it comes to that.... :text-lol:
When we aren't screwing around... something must be deadly wrong... :ychain:
Don
  • Haha 1
AMC RULES
:rolleyes: Oh, it's no joke.
WHX??-Uncle Jimbo swears by the stuff to relieve his dry, cracked dishpan hands.  :dunno:
  • Haha 4
Snoopy11
And feet. AND...
Oh well... I won't go there... :scared-eek:
Don
lynnmor
I use dish soap and hot water to clean them out.  Don’t forget to remove the petcock and bushing and replace as needed.  There is a fine screen on the petcock that needs to be in good condition.  You can’t get too aggressive with the gas gauge float in there.  An alternative is to rinse with gasoline till you get no more junk.
Horse Newbie
So here's the plan take the Palmolive and get some hot water but in the tank but a bunch of washers in the tank and shake it like the world's going to end.
Then rinse well and dry well, then NEW fuel line, NEW fuel filter, that crap may be in your fuel pump now… I’d get a NEW fuel pump too… then if she doesn’t run right CLEAN THE CARB…
