TJ5208 1,824 #1 Posted February 3, 2022 When I turn one tire forward the other one goes backwards what does this mean do they just do that. 520-8 Share this post Link to post Share on other sites
ranger 1,760 #2 Posted February 3, 2022 (edited) 19 minutes ago, TJ Salyers said: When I turn one tire forward the other one goes backwards what does this mean do they just do that. 520-8 Yes, unless you have a ‘locked’ / ‘welded’ or ‘limited slip’ diff. Then both wheels turn in the same direction if one wheel is turned. Edited February 3, 2022 by ranger 2 Share this post Link to post Share on other sites
Achto 27,750 #3 Posted February 3, 2022 20 minutes ago, TJ Salyers said: When I turn one tire forward the other one goes backwards what does this mean do they just do that. Yep happens with every differential. Cars, trucks, tractors, etc. Unless they are full posi traction. 1 2 Share this post Link to post Share on other sites
TJ5208 1,824 #4 Posted February 3, 2022 (edited) Okay just making sure Edited February 3, 2022 by TJ Salyers 1 Share this post Link to post Share on other sites
Achto 27,750 #5 Posted February 3, 2022 1 minute ago, TJ Salyers said: its not locked is the limited slip bad. Nope, if it doesn't slip some you will have a hard time steering. 1 Share this post Link to post Share on other sites
jeepdan 321 #6 Posted February 4, 2022 (edited) Yes, and when you lock the brakes up, and go skidding down a grassy slope, one wheel will be turning forward and the other in reverse. I'm going to come up with a plan to add brakes at each wheel. Edited February 4, 2022 by jeepdan 2 Share this post Link to post Share on other sites
Handy Don 12,444 #7 Posted February 4, 2022 17 hours ago, jeepdan said: I'm going to come up with a plan to add brakes at each wheel. Check out @Oldskool's thread on his Hiram build. 3 Share this post Link to post Share on other sites
