msdhomeplans@gmail.com
Carburetor Replacement
Hi I am trying to resurrect my fathers 1966 wheel horse lawn ranger.  I have gas leaking from the carburetor and I need a replacement.  I can not seem to find any accurate resources for the correct one needed.
Here are the specs for the tractor.  I am also in need of a seat for it if you know which work for this model.
Thanks in advance!
Model Number L 156
Serial # 219222
Wheel Horse Lawn Ranger L-156
Tecumseh H60
gasoline
1-cylinder
air-cooled
Displacement: 221 cc
13.53 ci
Bore/Stroke: 2.625x2.50 inches
67 x 64 mm
Power: 6 hp
4.5 kW
Starter volts: 12
Edited by msdhomeplans@gmail.com
pfrederi
Techy carb # 631067A
Just a leak may just need gasket and repair set 31840
Lots of cheap knock offs around.  Some work well others not so well you pays your money you take your chance.
 I usually try to repair the original first
Knock off and original
Edited by pfrederi
  • Like 6
Thank you for the quick response!
ebinmaine
I'd second the advice of trying to repair what you have.
Properly diagnose the actual issue before doing any repair.  (On anything really).
ri702bill
Once the carb is dis-assembled, hold it near your ear (or in my case, the good ear) shake it and listen for the sound of the check ball in the emulsifier tube to RATTLE - if there is NO sound, it is stuck and there is no positive way to clear that passage - time for a different carb. BT,DT
Bill
Handy Don
Bill
Someone here did a thread on drilling out the brass pin that captures that ball and using a small machine screw to seal the emulsifier tube back up after cleaning it out.
@squonk? @stevasaurus?
The issue is that the emulsifiers fuel passages (both the entry and exit) are extremely small.
Only time I've succeeded getting one unclogged was after a longish session in a friend's ultrasonic tank (too bad he's moved away and I'm too cheap to get my own).
Edited by Handy Don
stevasaurus
I think this is what you are asking about.  @rmaynard  This thread is in the Reference Section / Engines.
  • Thanks 2
Howie
I have tried to fix three of these, they all had a steel ball plugging that passage.
Used a Dremel with carbide burr, took considerable time. You have an aluminum
carb body with a black oxide coated pin in that passage. With water in the gas and
resideing in the carb for who know how long it is a recipe for trouble.
Wish they had used something else for the plug. At least the ones I tried were that
way.
  • Similar Content
    • wh315-8
      By wh315-8
      This is a tag on a 1970 Raider 10 from someone on a FB group. Never seen one that had USED on it, it is Model 1-6041 U
                Serial  342 USED.
      owner thought tag reads 2-6041 U for model but not sure.
      I just wonder if this was perhaps a warranty factory return and they used a new id tag this way?
      Anyone ever come across something like this?
       Typed in the numbers for Clarity.
    • Redtickuleez
      By Redtickuleez
      Hello gentlemen!!! I recently bought a d180 with loader and backhoe. Im looking for serial number.. there is a plate under the steering wheel but its been pajnted over and i can make it out. Can y'all tell me another location and was this tractor pruchased originally with these attachments and any info would be greatly appreciated... Thanks fellow Wheel Horse enthusiasts !!! !! !!!
    • Aaron Coffman
      By Aaron Coffman
      Hi Red Square Community,
      I am looking into purchasing the below pictured "POND" Walk Away. The unit itself has the cast in “POND” on the chain reduction housing. The two main things I am looking to learn are what value is typical for these to sell for. This one has a Briggs & Stratton model “N” engine. It runs and drives, but the throttle linkage needs some adjusting. It comes with a cultivator and plow implement.
      Secondly, I was wondering if there is any way to determine what year specifically this Pond is from. The seller believes late 1940s and not 1950s. I am new to these machines, so I am looking for some guidance. Thank you in advance!
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • ohiofarmer
      By ohiofarmer
      i know that there is ebb and flow with market conditions, but I have been seeing bargain 520 and c-160 prices more common. I recently saw a c-160 like model on a place other than here that was close by, but i did not get a chance to see it as I was still on a medical tether getting care. i say c-i60 like model because it was a series of numbers like 4455 or somesuch .Tractor had the k series engine clearly a sixteen HP and came with a decent looking deck and pusher blade. i called my buddy Jay and told him for the $250 ask , he better hustle after it. i really do not know if he did.
        I also have been seeing 520s and such lower than I can remember as well as the D series..My theory is that people experiencing paycheck to paycheck living are increasing in number.
      You even are seeing a lot more older trucks like square bodies and especially big blocks than you did before. we used to see this a lot in new trucks when fuel prices hit records.
      i am not claiming expert status on this, but it seems to be trending this way one county next to indiana and 90 miles North of the Ohio River.
       Tell me what you are seeing out there and what you think.
           Edit:  Jay and I ran up to buy Bob Ellison's tractor in MI.  Bob was very nice to deal with and included his "last seat"   I got super lucky buying my first C-160 that did not start and another one shortly dropped in to keep it company. The tractor described above was listed for only two days and was gone
