dwhjelm
adjustment for snow blade
dwhjelm
Is there any adjustment for how high the snow plow attachment will raise? Mine only lifts about 2" of the ground in the raised position.
oliver2-44
Are you using the solid lift bar are the lift chain. You can adjust the lift chain
dwhjelm
I believe I have a chain but it doesnt seem to have any room for raising it.
ebinmaine
What model tractor?
Model plow?
Can you post pics of what you are doing currently?
stevasaurus
Check out this picture to determine if you are in the right holes.  If you have the star wheel adjustment, you might be able to lower that all the way and maybe raise a link or two on your chain.  These will help, I also put a 2 x 4 under my blade to gain a link, but all of these will not gain you much.  It seems height is around 3".
ebinmaine
The front edge should clear the ground by 5 or 6 inches I'd think. You might be able to install spacers between the rear axle bracket and rear axle.
That lowers the rear which raises the front.
daveoman1966
My C-160 Auto with hyd lift will raise the 48" dozer blade about 5" max. I also have the SOLID LINK to put down pressure on the blade.  With that solid link, I can lift the front wheels 3 to 4 inches off the ground... That kind of DOWN PRESSURE is great for cutting thru hard-pack snow...
dwhjelm
I have a 1989, 414-8 not sure what plow model is. It is a manual lift and turn blade.
ebinmaine
Using the diagram posted by @stevasaurusabove you should be able to narrow down the issue.
ebinmaine
2 hours ago, daveoman1966 said:
SOLID LINK
Dave do you find yourself constantly adjusting that or no?
wallfish
Don't know about Dave but there's no adjustment for a solid link. Just pins at the top and bottom for the connections. If you make one you can drill holes and use bolts with nuts and drill extra holes for adjustments if you find it necessary.
daveoman1966
NO.  I can, but choose not to.  1272867155_LIFTLINKS.jpg.4b44dfb6624a40ce3ec47a52b1cffa14.jpg
