Christof421
C-121 snowblower issue
Christof421
Hello, I recently purchased a single stage snowblower attachment for my C-121.  Currently going through my first storm with it.   Made some passes down the driveway and blower was blowing a bit of snow backwards under the tractor.   Snow is very fine and light snow.   Wondering if anyone else has experienced this or has suggestions on remidies.
pfrederi
Depends on how high you set the guide wheels.  I f you have a smooth surface like asphalt you can set it very low and there will be little blow back.. i have uneven gravel/stone and I have to set themhigh so as to avoid beating the blower to death eating stones.  Then you get a lot of blow back.   I bring out the plow and clean up.  only use the blower when we get above 8-10 inches
  • Like 5
roadapples
Uneven driveway? If bottom of blower doesn't touch the whole way across it will do that. Can't hardly prevent it on a gravel driveway.
   And :WRS:
Paul types faster than me....
Edited by roadapples
Christof421
Thanks folks.  Yes driveway is a bit uneven.  I didn't catch too many rocks this time out so might lower guides a little next time around.
Achto
:WRS:
rjg854
:WRS:
It's common with the blower as has been mentioned.  Once I've used the blower, I then clean up with the plow blade.  Course that means you need a 2nd tractor with a plow :teasing-poke:  And that's how the addiction starts  :laughing-rolling:
  • Similar Content
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
    • mmmmmdonuts
      By mmmmmdonuts
      Tall Chute single stage snowblower. Has worm drive chute control. Has lift rod as well. Chute is currently detected for storage.
    • jebeli
      By jebeli
      Lets make a deal. The whole collection for $3000 or one tractor and half the items listed below for $1500.
      I am moving to town so am willing to do a partial trade for a wheelhorse more approproiate for a suburban lot- lawn ranger, surburban models, bcs walking tractor, other?
      I could possibly deliver or meet half-way or ship.
      Both tractors run great and are in good working order. Second owner of both machines. I work with these machines everyday so they are not perfect but are, in my opinion, in excellent shape.
      42in high-shoot snow blower
      42 in rear discharge deck
      Snow blade
      Front mount deck hanger with 42in side discharge deck
      30in lawn seeder
      Brinly single bottom plow with cleavis or sleeve hitch
      50in grader blade
      Extra transmission
      36in rear tiller - leaks a little
      Full set of tire chains for each tractor
      Various body pieces
      7.5 cubic ft pull behind cart - may need tires
      Extra set of rims
      All required belts, pullys, brackets, manuals, too much to list.
    • Baxtercr
      By Baxtercr
      Great condition C-121 for sale.   if any ones interested lets dm.    I'm based in North Yorkshire near Harrogate
    • 83mercedes
      By 83mercedes
      i am going to be getting a 518h with a snow blower as i am new to having a snow blower one thing i noticed was that the chains have a fair amount of play how much is to much ,and would like  a service manual or a manual that would give me these facts,thanks
