Moparfanforever 844 #1 Posted January 27, 2022 (edited) Does anyone have these mounted on a tractor ?? My question is , did the adaptors come with the bottom bar that locks in place ?? The only way I can see to get the locking bar out of a new attach a matic is to cut it out and weld it back into the brackets?? Not sure why WH even put the E clips on the outside of the lock bar , the two tabs are welded onto the bar and will not move side to side to remove it. Am I missing something ?? Thanks !! Edited January 27, 2022 by Moparfanforever 1 Share this post Link to post Share on other sites
Achto 27,515 #2 Posted January 27, 2022 9 minutes ago, Moparfanforever said: Am I missing something ?? I believe that the e-clips are holding a solid shaft that slide through a tube. If this is the case, there is a good chance that the shaft is brown welded (rusted) inside of the tube. Might need to apply some heat to the tube and a big hammer to the end of the shaft. Careful not to peen the end of the shaft or it will not push through, 5 1 Share this post Link to post Share on other sites
Moparfanforever 844 #3 Posted January 27, 2022 Well , call me dumb , never even thought of that !! This one is slightly bent , but I will get another and try a hammer and punch. Hopefully , I can find one that isn't brown welded into place. Thanks !! 3 Share this post Link to post Share on other sites
pfrederi 17,684 #4 Posted January 27, 2022 I have them mounted. You have to use bottom pin. As Achto said may be rusted but also that tube frequently gets bent making getting pin out a lot harder 4 Share this post Link to post Share on other sites
squonk 41,040 #5 Posted January 27, 2022 You can kind of see it in this pic: 3 Share this post Link to post Share on other sites
squonk 41,040 #6 Posted January 27, 2022 1 minute ago, Moparfanforever said: This one is slightly bent , but I will get another and try a hammer and punch. They get bent all the time from guys over tightening the mule drive mower belt 1 Share this post Link to post Share on other sites
Moparfanforever 844 #7 Posted January 27, 2022 Thanks for the pics !! I was afraid the adaptors mounted that way , I am going to have to cut the small brackets that are welded to the frame because my brackets hit the angle pieces and will not set flush. Share this post Link to post Share on other sites
squonk 41,040 #8 Posted January 27, 2022 What model tractor are you putting it on? Share this post Link to post Share on other sites
pfrederi 17,684 #9 Posted January 27, 2022 (edited) There are two models of the adapters. As I recall some modification was require by the installation instructions Edited January 27, 2022 by pfrederi Share this post Link to post Share on other sites
Moparfanforever 844 #10 Posted January 27, 2022 It is a 67 or 68 Charger , has the SG on it. I will snap a pic of what I am talking about. 1 Share this post Link to post Share on other sites
Moparfanforever 844 #11 Posted January 27, 2022 I will have to get the hood off to get a better look , but not sure I can use these on the tractor. Looks like I may have to take some metal of the bracket for the hood. 1 Share this post Link to post Share on other sites
c-series don 8,673 #12 Posted January 27, 2022 (edited) @Moparfanforever Can’t you put that on the other side of the tractor ? Basically switch the brackets around? Or will that make it too wide? Edited January 27, 2022 by c-series don 3 Share this post Link to post Share on other sites
Moparfanforever 844 #13 Posted January 27, 2022 I kinda sorta tried to fit it , but I think it will be to wide . Share this post Link to post Share on other sites
Moparfanforever 844 #14 Posted January 27, 2022 47 minutes ago, pfrederi said: There are two models of the adapters. As I recall some modification was require by the installation instructions Looks like I have the style of hood hinge that part of it will have to be cut off. Looks like I will have to get out the death wheels !! Share this post Link to post Share on other sites
Moparfanforever 844 #15 Posted January 27, 2022 55 minutes ago, pfrederi said: There are two models of the adapters. As I recall some modification was require by the installation instructions Thanks for posting this !! Share this post Link to post Share on other sites
daveoman1966 3,745 #16 Posted January 27, 2022 (edited) All ya gotta do is drill 3 holes (3/8") and bolt the Front Tach-o-Matic hitch to the Hood hinge plate. Here is a Raider 10 with the 'upgrade' installed . I am attaching a file "MULE DRIVE UPGRADE.PDF with narrative and pics for anyone's use. Here MULE DRIVE UPGRADE DETAIL.pdf Edited January 28, 2022 by daveoman1966 1 2 2 Share this post Link to post Share on other sites
pfrederi 17,684 #17 Posted January 27, 2022 Welding was not always a strong point for Wheel Horse. To put the adapter on one of my chargers i had to grind off a lot of excess weld between the frame side rails and the front plate. Share this post Link to post Share on other sites
Moparfanforever 844 #18 Posted January 27, 2022 Dave,I did read your post on doing this and I fit the mule drive up to the tractor and I am still going to have to cut some of the hood hinge bracket because the mule drive is to wide. Share this post Link to post Share on other sites
daveoman1966 3,745 #19 Posted January 28, 2022 8 hours ago, Moparfanforever said: Dave,I did read your post on doing this and I fit the mule drive up to the tractor and I am still going to have to cut some of the hood hinge bracket because the mule drive is to wide. If you use the THREE 1/2" ID square spacer nuts...as in this pic (MULE-17) ...the Front Tach-o-Matic hitch will fit snugly between the hood hinges...you MAY have to GRIND each top corner of the front hitch just a little (as in MULE-15 below), but it'll fit....as with this Raider. The two NUTS also make the front hitch VERTICAL. 2 2 Share this post Link to post Share on other sites
