Pullstart
Winter fun - Project “Freedom” 440cc 2 Stroke 1054 Snowmotractor
Handy Don
  On 2/8/2022 at 4:00 PM, Pullstart said:
Remember, the F plate on a 953/1054 is MUCH thicker than a smaller Horse.  3/8” or 1/2” thick if I recall.
Didn't know that and good thing to have in this application. Are the frame members also stronger?
Thanks for the info.
Pullstart
I want to say they are.  @953 nut?  Are the frames heavier?
Pullstart
Picked up some locking collars and fuel items at the hardware store.  Spending the big bucks!  $39 more out of the till.
  • Excellent 2
Pullstart
I opted to work most of last night instead of sleep.  Momma asked me to be in by 11 tonight.  Let’s see if I can make it that long!  Almost 5 hours!  :banana-wrench:
Oldskool
Sometimes when your on a roll ya just can't stop.
Guilty of that a few times.
Sometimes get cleaned up just in time to hop in the truck and head for work.
Pullstart
The steering shaft is welded up.  Another item in the swap that was almost meant. To. Be.
It’s practically on the exact plane as the front pivot point!  I will check the length of the tie rod or intermediate rod soon.
Oldskool
Well Wheel Horse did make a snowmobile.
Fate......maybe. 😆
  • Haha 1
TJ5208
Fate......maybe. 😆
Good point I did look at one the other day.
Oldskool
There is one for sale that has been taunting me for a couple weeks now. I just can't make the 9-10hr round trip at the moment.
TJ5208
Where's the one you're looking at.
Pullstart
Fate......maybe. 😆
I bet MY :wh: snowmobile will be better… :ROTF:
953 nut
:confusion-confused:      Don't remember the numbers but think the angle iron was 1/8" thicker and 1/4" wider than the 1055.
Oldskool
Southern Maine
TJ5208
  On 2/9/2022 at 12:33 AM, Oldskool said:
Southern Maine
To far from me I thought I'd steal it from underneath you:lol:
  • Haha 1
Oldskool
I wish you would so I don't keep seeing that ad.
TJ5208
Would you help me pay for it.
  • Haha 1
Pullstart
not to mention all the welded structure from the fenders, steering tower and tunnel. @Handy Don :handgestures-thumbupright:
The outside dimensions are 8” wide.
Edited by Pullstart
Pullstart
My throttle cable extension just left the nearest big city!  I should get it tomorrow!  :dance:
Handy Don
Yep, I've never looked closely at these "big" ones but I'll be checking them out at the next big show! (And I'll bring my calipers!)
We lost all our snow here in the last two days to rain and then sun. Sigh.
Pullstart
Good Lord willin’ and the Creek don’t rise, this one will be on display next Big Show too!
wallfish
With that variable pulley on the engine, Do you need to add another one on the trans too? Like a torque converter does?
Or can the belt slack be taken up as it changes with a spring loaded idler pulley on the normal clutch pulley spot? or something else?
Pullstart
I’m planning :handgestures-fingerscrossed: that it will simply act like a clutch.  Idle will slack the belt.  Rev it up and it bites… getting tighter and tighter until it’s closed.
Pullstart
Time for trailing arm mounts.  I turned one of these cuts…
into this:
Handy Don
Just the ticket for "stretching" the belt?! 😜
  • Haha 1
Pullstart
Both ends machined.
