Pullstart
Winter fun - Project “Freedom” 440cc 2 Stroke 1054 Snowmotractor
Pullstart
A not so amazing sketch.  Machines facing each other.  Engine should move directly over.  No rotation needed.
  • Confused 1
Pullstart
“Bring me to Life!”
  • Excellent 2
  • Heart 1
Bens vintage tractors
Here’s my newest video on my upgraded snow tractor.
  • Excellent 4
  • Heart 1
Pullstart
A quick video about the steering upgrades.  It might not matter.  It might get a whole different front end.  I’m not sure yet.
Pullstart
There’s gotta be something useful here!
Pullstart
Some useless plastic is outta the way..
There’s a good chance most of this suspension and maybe steering gets grafted onto the 1054 frame.
  • Like 4
Pullstart
Snoopy11
440 cc???
My Duromax is 457cc... :confusion-confused:
Don
Pullstart
26 minutes ago, Snoopy11 said:
440 cc???
Don
is your 457 4 stroke?  My 440 is a 2 stroke twin.
Snoopy11
Just now, Pullstart said:
457 4 stroke?
:text-yeahthat:
4 stroke single.
Don
Pullstart
As built as yours is, I think it’s still apples and oranges, right?
Snoopy11
Yes sir, I am just interested in the horsepower ratings at said RPM.
Sounds like you have a real hum-dinger there... :lol:
Don
Pullstart
My conflict right now is whether to offset the engine centerline to line up the drive pulley, or run the snowmobile clutch system and use the driven clutch as a jackshaft, and if jackshaft is the way to go, where to re-route the steering.
Snoopy11
:text-yeahthat:
That is what I did with my 457. Unfortunately, the engine was so wide... I had to offset it to line up with the drive pulley. I thought that it was going to look a bit odd... but with the exhaust and such, only I notice/know that it is offset.
I had to adjust it several times to keep ensure that it was lined-up. Also, as you probably imagine... you will need to find the belt size... which... for some odd reason I am good at guessing at... :dunno:
Also, I would recommend grade-8 bolts to hold that booger down... :)
Don
kpinnc
And a helluva lot of them! :lol:
  • Haha 3
Snoopy11
I like the fact that the polaris 440 has needle bearing supported crank with roller bearing crank journal. :banana-dance:
Image 2 - Polaris 98-00 XCR XC SP 440 00-04 500 600 XC SP RMK Crankshaft 2202257 2201234
Don
Snoopy11
I recommend Klotz 2 stroke oil, by the way. Best oil that I have found for these engines. :handgestures-thumbupright:
Want the Freedom project to be free to run for a long time! B)
Don
Pullstart
We’re looking at 41 and rain by Wednesday.  I hope it doesn’t take all the snow pack with it!
stevebo
On 1/27/2022 at 12:48 PM, Pullstart said:
I must say, @giddyap was my first inspiration, but Ben’s post on Instagram sparked Mrs. P’s interest for me to stick something together.
Showed brennanbo. He loves it!!
Pullstart
it kinda looks like your puller 953/1054!
stevebo
Sure does!!
Pullstart
I’m playing with motor mounts and belt alignments and whats nots today.  I think direct drive with no clutch pedal is going to work!
This might loose all brakes, potentially. :auto-swerve:
  • Heart 1
Snoopy11
That is how I envisioned it looking... :banana-dance:
Don
Oldskool
Was the pedal originally on the "passenger side"?
Pullstart
no. There’s still a pedal “driver’s side” so I suppose I could just trim the clutch arm off or use a shaft locking collar.
Edited by Pullstart
