Hardy 27 #1 Posted January 27, 2022 Bonjour, je viens d'acquérir un commando 7 et n'ayant aucun manuel je voulais savoir quelle huile mettre dans boîte et pont la quantité et peut être un additif car la boîte accroche un peu Merci d'avance pour vos réponses cordialement 2 Share this post Link to post Share on other sites
Achto 32,346 #2 Posted January 27, 2022 (edited) @Hardy Bienvenue au carré rouge I'll do the translation honors. Hello, I have just acquired a commando 7 and having no manual I wanted to know what oil to put in the gearbox and axle the quantity and maybe an additive because the gearbox hangs a little Thank you in advance for your answers cordially Here is the manual for you tractor. It's in English though. Voici le manuel de votre tracteur. C'est en anglais pourtant. Oil will be 80-90w You can add some Lucas oil treatment to it to make it more sticky. L'huile sera de 80 à 90 w. Vous pouvez y ajouter un traitement à l'huile Lucas pour la rendre plus collante. Hope Google did not mess the translation up too bad. J'espère que Google n'a pas foiré la traduction trop mal Edited January 27, 2022 by Achto 3 Share this post Link to post Share on other sites
WHX?? 57,793 #3 Posted January 27, 2022 @Maxwell-8 don't you speak French maybe help the guy out? 1 1 Share this post Link to post Share on other sites
Hardy 27 #4 Posted January 27, 2022 Merci pour votre réponse 👍 1 Share this post Link to post Share on other sites
Hardy 27 #5 Posted January 27, 2022 Quel type d'huile et quelle quantité en complément ? Merci à vous Share this post Link to post Share on other sites
Pullstart 71,089 #6 Posted January 27, 2022 A Commando 6 will tug some serious loads. I can only imagine an extra horse under the hood! Bienvenue! Un Commando 6 tirera des charges importantes. Je ne peux qu'imaginer un cheval supplémentaire sous le capot ! 1 Share this post Link to post Share on other sites
WHX?? 57,793 #7 Posted January 27, 2022 12 minutes ago, Hardy said: Quel type d'huile et quelle quantité en complément ? Merci à vous What type of oil and how much in addition? thank you 80/90 Poids huile pour engrenages. Environ 2 quarts ou (1,89 litres) ou jusqu'à ce qu'il apparaisse plein dans le bouchon sur le côté arrière gauche. 80/90 Weight gear oil. About 2 quarts or (1.89 liters) or until it apears full in the plug on the rear left side. 1 Share this post Link to post Share on other sites
Achto 32,346 #8 Posted January 27, 2022 15 minutes ago, Hardy said: Quel type d'huile et quelle quantité en complément ? Merci à vous What type of oil and how much in addition? thank you 2 quarts according to the manual. Either synthetic or petroleum 80-90w oil will be good. 2 pintes selon le manuel. L'huile synthétique ou pétrolière 80-90w sera bonne. You will want to raise the front of the tractor as high as you safely can when you drain the gear box. Doing this will allow the oil to get over the hump inside the gear box. Vous voudrez soulever l'avant du tracteur aussi haut que vous le pouvez en toute sécurité lorsque vous vidangez la boîte de vitesses. Cela permettra à l'huile de passer par-dessus la bosse à l'intérieur de la boîte de vitesses. 2 Share this post Link to post Share on other sites
WHX?? 57,793 #9 Posted January 27, 2022 Si vous le vidangez, notez d'abord à quoi ressemble l'huile qui en sort. Nous pouvons recommander une chasse d'eau. If you do drain it first note what the oil that comes out looks like. We may want to recommend a flush. 1 Share this post Link to post Share on other sites
Hardy 27 #10 Posted January 27, 2022 Merci à vous 👍 1 Share this post Link to post Share on other sites
WHX?? 57,793 #11 Posted January 27, 2022 Je t'en prie Your 1 Share this post Link to post Share on other sites
Ed Kennell 46,979 #12 Posted January 27, 2022 (edited) I'm impressed. I really could have used Jim and Dan when I was working in Switzerland. I only speak PeeAaaa Dutch and Appalachian English. No I gotta go change the oril and warsh Mrs. Ks van. Edited January 27, 2022 by Ed Kennell 1 1 4 Share this post Link to post Share on other sites
Pullstart 71,089 #13 Posted January 27, 2022 regardez-nous tous parler français! je n'ai même pas suivi le cours à l'école, mais tout est possible avec la machine google ! 1 1 Share this post Link to post Share on other sites
Achto 32,346 #14 Posted January 27, 2022 @Hardy Sure would like to see a picture of your new tractor. J'aimerais bien voir une photo de votre nouveau tracteur 2 Share this post Link to post Share on other sites
Maxwell-8 4,371 #15 Posted January 27, 2022 5 hours ago, WHX?? said: @Maxwell-8 don't you speak French maybe help the guy out? I will!! 10 hours ago, Hardy said: Bonjour, je viens d'acquérir un commando 7 et n'ayant aucun manuel je voulais savoir quelle huile mettre dans boîte et pont la quantité et peut être un additif car la boîte accroche un peu Merci d'avance pour vos réponses cordialement Wheel Horse recommande le 80w90 GL5. deux litres suffit. Que voulez-vous dire par "accroche " ? Est-ce que ça fuit ? Cela signifie que les joints de arbre d'entraînement s'usent. un additif ne va pas résoudre ce problème. 3 Share this post Link to post Share on other sites
Snoopy11 5,731 #16 Posted January 27, 2022 Si vous voulez mes conseils, j'irais avec Lucas Oil 10043 Heavy Duty 80W-90 Gear Oil. Ce que tout le monde ici a dit fonctionnera très bien, mais la « meilleure » protection pour votre transmission, à mon avis, sera l'huile pour engrenages Lucas. Je suis sûr que @peter lena serait d'accord... Don Share this post Link to post Share on other sites
Hardy 27 #17 Posted January 27, 2022 Les vitesses accrochent obligé d'embrayer et débrayer en passant la vitesse . Share this post Link to post Share on other sites
WHX?? 57,793 #18 Posted January 27, 2022 (edited) 41 minutes ago, Hardy said: Les vitesses accrochent obligé d'embrayer et débrayer en passant la vitesse . Gears hang forced to engage and disengage when changing gear Je vidangerais l'ancienne huile puis je verrais à quoi ça ressemble. S'il est de couleur marron laiteux avec des signes de rouille, il se peut que de la boue accroche les rails de changement de vitesse. Vous devriez alors le rincer. Avez-vous eu un temps sous le point de congélation là-bas ? Il peut y avoir de l'eau qui cause des problèmes. I would drain the old oil out then see what it looks like. If it's milky brown color with signs of rust in it you may have sludge hanging up the shift rails. You should flush it then. Have you had below freezing weather there? It may have water in it it causing issues. How's my French Max? The old cut n paste working? Edited January 27, 2022 by WHX?? 1 Share this post Link to post Share on other sites
WHX?? 57,793 #19 Posted January 27, 2022 5 hours ago, Pullstart said: regardez-nous tous parler français! je n'ai même pas suivi le cours à l'école, mais tout est possible avec la machine google ! The only French you know is what comes out when a 5/16 gets stuck in hand! 1 3 Share this post Link to post Share on other sites
Pullstart 71,089 #20 Posted January 27, 2022 (edited) 7 minutes ago, WHX?? said: The only French you know is what comes out when a 5/16 gets stuck in hand! It was a 7/16”… or about 11mm! Edited January 27, 2022 by Pullstart Photo 2 Share this post Link to post Share on other sites
Hardy 27 #21 Posted January 27, 2022 Rinçage boîte et pont au gasoil ? 2 Share this post Link to post Share on other sites
