tunahead72 2,422 #26 Posted January 24, 2022 3 hours ago, ebinmaine said: Any of you woodcutting folk change chain oil season to season? I didn't until just very recently... I took my Stihl apart to replace the oil pump, and one of my local parts guys recommended using their BioPlus bar & chain oil in cold weather. I had been using their Platinum oil, which he said is too thick at lower temperatures, by which he meant anything below about 50°F. I haven't been able to test it fully yet, but I did start it up yesterday without the bar and chain installed (I know ), ran it for just a couple of minutes at low to medium throttle, and I got a decent flow of oil out the discharge hole (temps in the low 30's). We'll see how it works once I sharpen the chain and put it all back together again. 1 1 Share this post Link to post Share on other sites
WHX?? 48,823 #27 Posted January 25, 2022 (edited) Thank you for putting this thread back on track Ed.... here I thought we was gonna have an edumatcted thread on wood cutting in the winter ... silly me. Might have known it was gonna go ten pages and I wouldn't a learned a damn thing. For your info Squonky I only use bottles that have ode de skunk like you use in your washing machine. Not that I don't listen to the saw experts Tuna but I won't use drain oil like on Alaskan bush people or the high tech oils touted by the saw guys ... yah big margin in that stuff for them and I know they got kids to feed but I just buy the big box chain oil and thin as needed. More important EB to file the bars as needed and flip it. I cut 'till the saw runs out of gas or oil ...hit the chain with a hand file and get at her again. Bring it in to shop for power sharping if I hit a nail or most often stick it in the dirt. Now you should know this EB guy has gotta have two saws out in the woods ... one with a $hit chain and one that is tuned. Use the appropriate one for the situation. Edited January 25, 2022 by WHX?? 3 Share this post Link to post Share on other sites
ebinmaine 67,550 #28 Posted January 25, 2022 1 hour ago, WHX?? said: Now you should know this EB guy has gotta have two saws out in the woods ... one with a $hit chain and one that is tuned. Use the appropriate one for the situation Habit I've developed over the last couple years is to bring 2 full chainsaws and one electric sawsall. Sawsall gets the dirty work. 1 Share this post Link to post Share on other sites
WHX?? 48,823 #29 Posted January 25, 2022 Yep I use a sawsall for cutting up pallets for the pit. Nails in trees from old deer stands or trespassing signs can knock a good chain down to parade rest real quick. 3 Share this post Link to post Share on other sites
oldlineman 1,481 #30 Posted January 25, 2022 I have found that when I see a blueish stain in a log there is a good chance that metal is lurking close by. Bob 1 2 Share this post Link to post Share on other sites
