RED-Z06
This followed me home...
RED-Z06
Always wanted one, had a 316, 317 and 318.
  • Excellent 2
Achto
I have a friend who has always wanted that model. He told me why, now what was it? :confusion-confused: Some meaning behind that number.:confusion-confused:
BTW Nice tractor!! :handgestures-thumbupright:
Edited by Achto
  • Haha 5
RED-Z06
Its the magic cheech and chong number 🤣
  • Haha 1
Snoopy11
That's got an Onan in it, correct?
NICE... :bow-blue:
Don
RED-Z06
Im hoping this one doesn't have "the governor problem" but darned if i dont think it might...
RED-Z06
Onan P220G, 2spd Eaton90, 874hrs.
Snoopy11
Decks on these older John Deere mowers are... ehem... STRONG... :)
Don
Jeff-C175
Pass da dutchie from da leff side mon !  :omg:
  • Haha 4
SylvanLakeWH
Meh…
I hear they changed the model number… too many getting ripped off for some reason… :confusion-confused:
:banana-linedance:
  • Haha 4
RED-Z06
Don
Seemed like through the 70s, 80s and early 90s few companies made any real effort to make a decent deck.  Deeres were too thin, wheel horse tended to crack ar the roller bar or fold up from strikes, Simplicity...made no effort, snapper GTs were not bad, Kubota decks cracked and fell apart, ropers were decent but rusted fast
RED-Z06
Then the 425/445/455, 325, 345, 355...etc models, beefy decks
Pullstart
  • Haha 2
T-Mo
I didn't have a 420, but I had a 400 and a 430 in the past.  Both were beasts.  I also had a 445 and a X720 which are decedents of the 400 line.
A bit of John Deere 400 series history.
400_series_Garden_Tractors-64276.pdf
  • Heart 1
RED-Z06
Got the engine ready to hoist out today, things i need to do while its out...
Replace governor spacer
Inspect why the starter sounds so awful
Adjust valve lash
Inspect intake for leaks (prevention)
Pull heads and Inspect valve seats/bores.
Change oil and filter
RED-Z06
Engine is out, start to finish it was out in about 20 minutes, got it torn down this afternoon, plastic spacer came off too easy, i heated the steel new one, cleaned all the mating surfaces and put it on..a few hammer strikes it was seated in.
Cleaned my balls up, and my cup..😐, and assembled it back, ensuring the hole was at 3oclock.  Also chanced the flywheel side crank seal.
Valve lash is all over, ill set it tomorrow..one valve has no lash at all.
The only problem i encountered is, it ate a screw at some point, right side piston took a beating but looks superficial.
RED-Z06
Mostly done...runs like new now
  • Like 4
RED-Z06
Handy Don
2 hours ago, RED-Z06 said:
Very nice work, These are very nice machines, especially with the triple hydraulics and PS like this one has. Never did like the front belt routing that powers the mower deck though, a common problem with longitudinal engine placement.
Enjoy it!
RED-Z06
Enjoy it!
This one has a shaft driven deck off the front pto, Twin belts  down to a pulley on a shaft. The 316/318 had the mule drive similar to wheel horse with twisted belts
Handy Don
Do you have a picture of that you can share? Sounds interesting. Thanks
Also just noticed the separate rear wheel brake discs (you didn't post a right side image so I didn't see the pedals :)).
Edited by Handy Don
RED-Z06
This gives it a 2000 rpm front or mid shaft driven pto
RED-Z06
Tractor itself is nearly complete...engine runs like a top.
Deck is...very rough, ive got it stripped down bare, refinished the spindles, brackets, temsioner, pulleys, stripped the hardware, new gauge wheels...waiting on supplies for the shell itself
RED-Z06
RED-Z06
Well, the engine laid down after 45 minutes of mowing, seller didnt disclose the engine had a loose valve seat and the block was ruined, so...10 months later i tracked down a used correct 1- 7/16" pto engine and after welding up the broken starter mounts...it purrs.
Still have to yank it back out and replace the governor spider..but at last it lives
