Ifixoldjunk
310-8 dipstick slime
Ifixoldjunk
so ever since I’ve owned my 310-8, I’ve been plagued with what appears to be condensation forming in side my engine.46D7EA44-C197-494B-87DB-BEF2AA9AE551.jpeg.02b44098a2dcf6266cea2d246c719a28.jpeg
after the initial wipe and re-dip it mostly goes away save for a little discoloration here and there. I’ve seen engines with water in the oil before. And this is pretty minor compared to that. My question is would you even be concerned about this? It’s been a constant issue since I’ve owned it.
forgot to mention, this is only a problem when it starts to dip below 40 outside. It’ll go all year long with perfectly clean oil until it gets a little chilly
Edited by Ifixoldjunk
  • Sad 1
SylvanLakeWH
Never had that on my C 105… hhhmmm.
Stored inside? Any exposure to elements? Is it consistent winter / summer? ie. cold / warm ambient temps?
Ifixoldjunk
It lives in a insulated garage. Not heated though. This only starts to become an issue when it’s cold out
SylvanLakeWH
While you were responding I checked mine. No such issue… and it’s been cold here in Michigan!!!
looks like water issue / condensation to me…
I run 30 wt rotella. Year round. What oil do you use?
Ifixoldjunk
I use some master mechanic brand 10w30 for winter, and same brand SAE-30 for warmer seasons. Pretty regular changes too
RED-Z06
We see this alot in engines thst are short run...it takes about 20 minutes of full power running to get the oil up to temperature and only then will it begin to boil off condensation, a good hard hour every now and then should be enough to keep it from accumulating.
Where i used to work we would crank a few mowers in the morning to put them out and in the evening to bring them in...if a mower did this for a few months we might get a few ounces of unburned fuel and condensation buildup and the oil looked like milkshake
  • Like 5
rjg854
The 12 HP I have in my Raider does the same thing. All last winter it was like that. I noticed it's doing it again. It's a fresh oil change just before winter. None of my other tractors are like that.  :confusion-scratchheadyellow:
  • Sad 1
Ifixoldjunk
You ever have any problems come from that? I’m kinda afraid to run mine with the oil constantly getting condensation in it.
rjg854
No problems at all, runs fine, I don't notice any effects. I wondering if it might have something to do with the crankcase breathing properly, now that I think about it. The front of that engine is pretty dirty.
Ifixoldjunk
That might be it. I’ll have to check mine
squonk
Cold air cannot hold as much moisture as warm air. The moisture will condense on cold metal. Really see this issue when there are wide temperature swings in a short period of time.
Ifixoldjunk
“Wide temperature swings” just about described life as a upstate New Yorker
SylvanLakeWH
Simple Fix… more seat time, longer running of engine, problem solved… :handgestures-thumbupright:
:banana-linedance:
rjg854
Seems odd if that was true because it only happens to one certain tractor. And not to the other 4 in the same conditions in the same building.
SylvanLakeWH
:text-yeahthat: Seems odd… I’ve never seen it in my 10 hp kohler and Michigan is similar (although obviously Superior) to New York… major temp swings… :confusion-confused:
  • Haha 1
Wheelhorse#1
Condensation.Run it more and harder get it up to temp.
Ifixoldjunk
Yeah. I have a bolens 1050 parked right next to it. And I’ve never seen any condensation in it
  • Confused 1
Ed Kennell
I see this condensation in my 312H.     It is kept in a heated garage.   I do use it as my wood hauler and I leave it running while I load the trailer. So it's probably running outside once a week for 30 minutes then back in the heated garage.   Guess I'll start taking a 1 hour trail ride when I bring in the wood.
8ntruck
I saw the same thing in the V twin in my Generac back up generator when I changed the oil this fall.  It normally runs 10 minutes a week in an operational self check.  I'm suspecting in cooler weather, it does not get hot enough to cook the condensation out.
I wonder if a crankcase heater on a timer would help?
kpinnc
Does the dipstick have an o-ring at the top?
Not trying to be a wise a$$, just wondering. Some did, some didn't.
squonk
Yup. Air with moisture in it gets in where it can. Try swapping the dipstick with another tractor and see if the issue moves to the other one.
squonk
How often do you check the oil on your cars? You'll find it there too. Not really a big deal. Engine runs and breathes. When it shuts off and cools, moisture in the air inside the engine will condense. The only 2 ways to avoid it are keep the engine very warm or move to Arizona.
giddyap
My 314-8 has the same problem condition. I bought it used with a 1000 hours and after 2 oil changes the slime remains. It would be nice to know what causes it but I'm not worried
giddyap
I found this complaint on a Generac Generator trouble shooting forum and the consensus is related to running time. Milky oil became common in the newer units with a "exericise" time of 5 min per week when the older models were 12 minutes per week. One comment said the condensation burned off after the unit ran for 2.5 hours under load but my condensation remained after pushing snow for 2 hours. I will live with it and consider it one of life's many mysteries.
peter lena
@Ifixoldjunk , think you answered your own question , with run time and outside temp, longer run time , I  usually add in my PTO LEVER DRIVE , to with added engine work , not much , but try to thoroughly get it hot , use all my gears , drive in reverse ,etc. the hotter and longer the run the less condensation you will have . also agree with relatively fresh oil , just regularly run them to keep  them up to date . always verify total operation function at that time too. that oil type incandescent  bulb , in reflector under my engines also helps to keep it warm over winter , thats only me , pete
