tomabrown77
5060 transaxle
tomabrown77
my 1067 stopped moving; limited slip had worn out long ago;  now input pully is turning , but tractor doesnt move --- very slight motion forward or backward if on level ground with no resistance.  Enough to tell me shift lever is actually changing gears.
I suspect input shaft woodruff keys but might be something worse ... i am interested in perhaps buying a new, used,or rebuilt  transaxle if someone has one they would part with.  And any advice on opening up the transaxle and looking inside .  Or where i can find parts to rebuild it myself...
ps i was on forum about 5 years ago,  forgot my username so i joined again
Edited by tomabrown77
add parts availability to rebuild option
pfrederi
Very possible input pulley woodruff key.  Make a mark across the shat and try moving it does the mark move.  Also check you hubs for slippage,  Bad key there can cause same thing.
Welcome...
Edited by pfrederi
  • Excellent 1
  • Thanks 1
Achto
:WRS:
If you find that you have a need to open the transmission, @stevasaurus has made some excellent video's to walk you through.
https://www.youtube.com/channel/UC0WxpigBM-CFt3jm0aCxvxw
If you find your self needing replacement parts for your transmission, here is one source.
https://wheelhorsepartsandmore.com/product-category/manual-transmissions/
stevasaurus
If you have not done anything to rip the teeth off of pinions in the differential, it almost has to be a wood ruff key in one of the hubs or the input pulley.  This is the 1st place to look...and the easiest to fix.  Marker lines across the hub and axle will tell you if something is slipping and the same with what was stated above.  Remember, it only takes one key way to be slipping to have what you have.  Check that 1st and let us know.
   BTW Welcome to Red Square  :occasion-xmas:   If it turns out to be something in the transmission, we can walk you though fixing it...it is not hard and all parts are available.  Just in case you want to know what a #5060 looks like inside...check this out.
  • Like 3
roadapples
:WRS:
tomabrown77
thanks!   I already checked the input shaft - it is turning with the pulley.  I didnt think to check the wheel hub keys --- since the limited slip has worn out, one of those would produce the same symptom....
tomabrown77
i did find that parts source -- thanks.... Dont know what i need yet.  .  If it matters, i didnt hear any 'bad metallic' sounds or feel any sudden change.,,, was plowing snow and just lost its 'desire to move'
tomabrown77
PTL  yoiu guys are Great -- woodruff Key on right drive wheel hub was sheared off. Now i need to buy one and a spare....Thanks!!!
  • Like 4
  • Thanks 1
Jeff-C175
Get 10, ya never know!  MIGHT be a #22 but double check first of course!
Edited by Jeff-C175
roadapples
:text-yeahthat:pull it before you order. I've seen 2 different ones on the same tractor...
953 nut
Any good hardware store should carry  an assortment of Woodruff keys, our Ace has them in stock, bring in the old one to match up.
  • Like 3
tomabrown77
i got tow at HW store -- parts list called for # 15, and putting the two sheared pieces together and measuring, it looks like it is was a # 15.
 I plan on replacing both sides
add to comment
  • Excellent 1
tomabrown77
I decided to change the oil in transaxle while i was replacing hub woodruff keys, the spec says 2 qts;  i saw on another thread that 2 qts level is above the side "filler" port/plug.   That doesnt seem logical to me - why have a side plug if the fill level is higher than this plug???  May i make a guess that maybe the 2 qt spec is what the case would hold up to this port without parts inside?  normally transmissions are filled about halfway, rotation of gears spreads it everywhere and the side port is a little above halfway up....
 Any thoughts?
another question -- are axles seals easily replaced by removing hub, pulling out old seal, and tapping in new one?  then re installing hub/wheels...
add clarifying phrase
Jeff-C175
Yep, pretty much.  You can use the hub as a 'slide hammer' to drive the seal in square.
pfrederi
WH felt that the limited slip 5060 tranny needed more oil to adequately keep the differential lubricated.  Your tranny should have an extension on the level plug (#71/72).  Fill it til it runs out.  I think you will use at least 2 qts.  The over flow others talk about is from other trannies with out the extension.
Edited by pfrederi
  • Excellent 1
tomabrown77
thanks -- that makes sense --- i didnt think i had the extension, but looking closer i actually do - only about 1/4 inch of part 71 is visible.  took about 1 1/2 Qt to fill to plug. maybe it wasnt completely drained, but i did let it sit and drain to just a drip .
pfrederi
There is a lump in the bottom of the transaxle case you have to raise the front of the tractor to get it to drain completely.  If it came out of the plug you are fine...
  • Excellent 1
WHX??
Late to the party here but sounds like the boys have got you well covered.
The 5060 is my personal favorite tranny. simple and bullet proof.
:WRS:
tomabrown77
i still marvel how my 1067 with this 5060 is a 10 times stronger workhorse than newer lawn tractors with supposedly  twice the power....
  • Similar Content
    • aaronthomas57
      By aaronthomas57
      Hello Everyone,
      The information here has been invaluable as far as getting this old wheel horse I purchased back in service. Some parts home made, the motor generator is ripped off a 2013 Yamaha, some salvaged parts.
      I bought this little bastard some months ago, it had to be dug out of the previous owners yard and lifted with a backhoe. It had not ran in about 40 years.
      Thanks for taking a look.
    • BAM1
      By BAM1
      Starting a slow restore to a C-160, Today she got a new fuel tank, and different tires. Started it up and went for a ride under her own power, first time since '08.
      Next comes finding the fuel leak, looks like a bad hose. and maybe some cleaning of the oily parts.
    • Mikey j
      By Mikey j
      Hi everyone, I have a 1969 raider12 6speed trans, Thant I’m going to change the oil in. But I don’t have a dipstick how do I get the two quarts in there? i tried filling from the side port only got about 700mils in. Thanks in advance!
    • stevasaurus
      By stevasaurus
      I finally got a chance to rebuild a transmission with a hi/low mechanism.  This is a 6 speed #5060 transmission with the 10 pinion limited slip differential.  Notice the brake shaft comes out the hole closest to the axle housing.  The 8 speeds brake shaft comes out of the cluster shaft hole.  I did a series of videos for this thread along with some pictures.  The videos are split up between different phases of rebuilding...ie...the differential, the hi/low shift mechanism, the rest of the gears 1 & 2 (my batteries died in the camera).  Most of the information will be in the videos...be advised that I did some struggling while doing these videos and I left them as is because it is not always easy.    Hope this helps you guys.
      correction...
      According to the manual the bolts that hold the differential together are in backwards in the video.  The nuts should be on the input shaft side (right side) of the transmission.  Sorry, I missed that.
      Just got the trans split.  I use a 1" old wood chisel to start and then work the case apart with a pry bar.
      A couple shots after getting the case half off...trans is in neutral.
      The trans case works as a work bench for the differential...very cool
      Here is the reason the trans needed to be opened.  An axle gear lost it's teeth and the pieces were lodged in the pinions.
      Finished and back together.
      The rest are the videos...1st on is the differential...
      Next 2 are dealing with the hi/low mechanism...1st one taking apart and the 2nd on putting together...be nice...it was my first time.
      Now, 2 videos putting the rest of the trans together...batteries died just before I finished the first video.
      Thanks for looking
    • BMW1
      By BMW1
      I have not had to do this before and want to make sure I'm doing it correctly.
      Picture of bearing and seal is attached.
      Is the bearing supposed to fit in the groove of the oil seal or is the seal supposed to flush against the bearing?  I think the latter is correct?
      Thanks
