Joe 77 B100
Best tires for snow.
ebinmaine
35 minutes ago, lynnmor said:
There is a downside to adding weight, you have more weight to carry up a hill and more weight to stop going down.  You need to make a judgement on your particular situation.
Absolutely agree with the part I put in bold, above.
On a wheel horse in particular that's definitely a valid point and I'm glad you brought it up.
On my rough terrain and hilly Forest land I've run 8, 12, and 16 HP engines.
Although I have to admit there were power differences between the two lower ones, and the 16, I found all to be adequate. That said, it should be noted that I'm moving some pretty heavy total weight at well over a ton between tractor and trailer, I'm only doing 3.5 to 4 mph Max.
