sjoemie himself 3,068 #26 Posted January 18, 2022 (edited) Stainless can be welded with stick, TIG, and MIG. Although TIG is the most common process for welding stainless as far as I know. 4 hours ago, Horse Newbie said: I called what he did with his foot a “gas pedal”… I’m pretty sure it controlled the wire feed speed… The gas pedal is for the welding current, up or down, depending on material thickness and/or needed heat input. The wire you use when TIG welding is (almost) always fed by hand. When MIG welding the wire does feed through the welding gun on torch. Edited January 18, 2022 by sjoemie himself Typo, again 😅 1 Share this post Link to post Share on other sites
Horse Newbie 7,057 #27 Posted January 18, 2022 1 hour ago, sjoemie himself said: Stainless can be welded with stick, TIG, and MIG. Although TIG is the most common process for welding stainless as far as I know. The gas pedal is for the welding current, up or down, depending on material thickness and/or needed heat input. The wire you use when TIG welding is (almost) always fed by hand. When MIG welding the wire does feed through the welding gun on torch. Thank you my good man for clearing that up… 1 Share this post Link to post Share on other sites
