ebinmaine 67,455 #2 Posted January 15, 2022 Neeeaaat 1 Share this post Link to post Share on other sites
Racinbob 11,063 #3 Posted January 15, 2022 That is just too cool! 2 Share this post Link to post Share on other sites
peter lena 8,620 #4 Posted January 15, 2022 @AMC RULES , think its awesome , reflects common sense get it done build / experimental way to go . the main thing it needs is a weather cab , thinking about a plastic bubble front , add on tube frame for sides , engine heat , ducted for comfort. as was emphasized , the total ease of operation , traction , was good. that articulated front blade , and the flat open driveway , makes that a real fun run. very impressed with the front swivel wheel function , would not be surprised to see a later upgraded show of this , without a doubt he will finish it , pete 2 Share this post Link to post Share on other sites
Pullstart 62,840 #5 Posted January 15, 2022 I like the idea of the hanging weights! I feel like I could benefit from those during mowing season even! 2 Share this post Link to post Share on other sites
peter lena 8,620 #6 Posted January 16, 2022 @Pullstart agree with the hanging weights , having an almost perfect spot for them , just behind the wheel area, also helps . think he will put on small side slide tubes for a slide in mount area for vinyl siding , frame , possible front windshield mount , easy on and off . personally I think he will finish it off , correct plow blade levers , etc. he is showing too much to let it stay that way , pete 1 Share this post Link to post Share on other sites
