Onan 16HP (520H) engine with broken rod to Kohler Engine K241
By
Tim Ziethen, in Engines
Similar Content
By rwlvt
Hi folks,
I tried to help a friend with a Toro 520H that won't start.
https://photos.app.goo.gl/19fPX79LGMPCBcnB6
(Attempting to insert a photo by URL doesn't seem to be working.)
Here are some identifiers for the engine:
Engine Model: P220G-I/109556
P/N941811
S/N: A973636148
I went through the usual--checking for spark. I'm getting spark in both cylinders. So, i'm looking at gas. There is a fuel pump on the side of the engine.
https://photos.app.goo.gl/RY4hHAfLLGeyCBaS8
I pulled the gas line below it and am getting gas from the tank. I pulled the line above it and cranked the engine. I wasn't getting anything! So, I assumed it was a bad fuel pump. I ordered and installed a new fuel pump, but still no luck. This is a vacuum actuated pump, so I pulled the pump and stuck my thumb over the tube while I cranked the engine. I expected to get either a vacuum or compression. I got neither. Any thoughts about where I go from here?
Thanks in advance,
Ron
By Rob R
Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216. He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
By t_furl43
A really nice 1995 wheelhorse 416H runs and drives great no leaks only 920 hrs, motor runs strong, starts right up, brand new back tires 23x10.5x12, has slot hitch, comes with 42” RD deck and 42” snowplow, wheel weights and all 4 hubcaps, I’ll also throw in an extra set of tires, will need a seat but that’s it, pickup in millersville pa 17551, price is negotiable, will trade for an Economy Powerking tractor or John Deere 318
By Ifixoldjunk
So I have a parts 310-8 I’ve been trying to get running. My problem is the engine runs for 5 minutes and then starts sputtering and shooting exhaust back out the carb. Any clue what is happening? I’m pretty lost.
By richm1386
Quick story and a couple of questions concerning replacing the ignition coil on my '89 416-8 with Onan P216 engine.
So I got this old tractor from my Dad when he replaced it and it was running okay until a few weeks ago. Was picking up sticks and hauling them out to the wood pile when I idled down the tractor and then it stalled out (which happens all the time.) I tried starting again and it would not turn over. The starter would go and go but no ignition. I spent a lot of time on these forums and found some really good info including the service manual. I used that diagnose the problem and figured out the coil was bad. I ordered a new off brand coil and condenser from Amazon for $40 swapped them in last night and it fired almost immediately. Plus since I had taken the shroud off and disconnected the throttle cable it was idling well at very low throttle. I've still got to reassemble everything properly but it seems like the coil was the culprit.
That said I've got a couple questions.
1. Anybody have any luck with non-Onan coils?The one I got from Amazon seems well made but it is literally some no name part. I figured for $40 it was worth a shot.
2. Does it matter which spark plug attaches to which plug on the coil? I forgot to take a photo before I disassembled.
3. Could a failing coil cause very hard starts and stalling at low idle? I'm asking because as I said above the tractor has been very hard to start for years. Almost always needed to choke it. It would also stall out if you idled down nearly every time. Just the brief testing with the new coil that I've done, both of these issues seem much better. Also I used my Dad's replacement (early '90s 416-h with same engine) for this tractor while working on mine and it started and idled very easily. It looks like it might have a replacement coil as well. Just wondering.
Thanks all.
