Tim Ziethen
Onan 16HP (520H) engine with broken rod to Kohler Engine K241
Tim Ziethen
Does anyone know what is required to swap out the Onan engine with broken rod on my 516H and drop in an good working engine from my 310-8 parts tractor?  I have read all the posts I can find but the ignition and charging circuit and wiring compatibility is not clear.  Thanks for the help!
gwest_ca
Welcome to the forum.
What is the Kohler spec number on the 310 engine?
The 516-H should be a 1988 tractor model 31-16OE01
Where does the 520-H enter this combination?
Tim Ziethen
Sorry it does not - my mistake on typing!
The tractor is a 516H with what I believe is a broken rod - engine running on one piston now.  I have a 310-8 parts tractor - do not have the engine spec right now, will have to post it later but it is a 10hp Kohler k series that I believe is a k241s that runs very smoothly.  So I was hoping I could take the 310-8 engine and put it in the 526h at least for now while I tear down the Onan to see if it can be salvaged. Only plan on mowing with a 42 inch deck.
Again - thanks for any and all help!
Tim Ziethen
Also the seat pan was painted on the 310 and the serial number is not readable - have to take a picture on the engine and confirm the series if possible.  You are correct on the 516h model number.
Thanks
Maxwell-8
Sure is possible.
Hydro may but a higher load on it.
You lost compression on that cilinder?
Tim Ziethen
Bought tractor as "running" but when I picked it up the seller clarified that the piston on the inboard side (by the tower/seat) was not moving so I suspect a broken rod.  What is surprising is the engine was/ is running "fine" on the single cylinder.  Rough and shaking but running.  I have heard of rods (always the rear one) breaking/snapping on this engine with little or no other damage - hoping that is the case. This is the one without a pressurized oil system and no oil filter, only oil slinger.
Anyway - for now I would love to swap the engine from the 310-8 just to have a working tractor and the only thing I am planning on using with this is a 42 inch deck and maybe a snow blade.  It has the Eaton 700 hydrostatic transmission on the 516H.
I do not know what is required or compatible from a wiring/charging voltage point of view - hearing that the K series and Onan were very different wiring.  Has anyone done this type of swap?  Thanks
Achto
Most important thing to know. Are both engines battery ignition or magneto ignition? If they are both one or the other that will simplify things. If you have one of each then you will have to change out the ignition switch. A switch with an "M" terminal is for a magneto ignition, A switch with an "I" terminal is for a battery ignition. You may also have to reconfigure plug for the ignition switch if you have to change it. I would down load the manuals for both tractors from this forum and compare the wiring diagrams to see what will need to be changed.
Edited by Achto
Tim Ziethen
Thank you - hoping a member did this and can weigh in on steps
oliver2-44
The hydro will suck 2 hp from that 10 hp, so you will be left with about 8hp to turn a deck, 8hp is really stretching it to turn a 42" deck.
RED-Z06
Yeah 42" is pretty much all a 10hp will like, my K241 with the 42" deck is running no less than about 40% governor at all times and thats with the 8spd, not sure it would do it with a hydro also.
pfrederi
Over the years 310-8 came with K-series then Magnums.  What spec number is your donor.
roadapples
:WRS:
Tim Ziethen
Sorry for delay - the donor engine is a kohler k241s spec 46863
Thanks for any help!
kpinnc
  On 1/15/2022 at 1:56 AM, Tim Ziethen said:
k241s spec 46863
That spec at least appears to be correct for the 310-8 line of tractors. That being said, you're gonna have some modifications to do to make a successful swap. Will it work? Absolutely. Will it be easy? Depends on your electrical skillset and willingness to modify the electrical system. You're also gonna have to decide how much safety interlocks you're willing to wire up.
My opinion only- physically swapping engines should be easy. Remove the Onan and mounting plate, and the Kohler should bolt right in. Thats where the similarities end.
Again my opinion only: I would carefully remove the factory wiring harness and start over. You'll need a keyswitch that works with a 12v coil and points ignition. The electrical fab work required to make the engine run is fairly simple. Safety switches being implemented will be at your discretion.
And the last thing to consider: as has been previously said, you are going to be limited with what that 10hp will pull. Any powered implement will max that leftover 6-8hp in a hurry. It's plenty to drag non powered stuff, but mowing with 36-42 decks will be all it will do.
The P216 may be expensive to repair, but likely worth it if the block and crank is undamaged. It's a bit more rare for the 16 to throw a rod than the 20hp. I hope the valve seats weren't the cause, but even that can be fixed by a good engine shop. You won't know until you get in there to see what broke and why.
Tuneup
  On 1/15/2022 at 7:12 AM, kpinnc said:
<snip>
Yeah, what he said! You might have less trouble repairing that Onan than retrofitting a 10HP. Oh, I have that same engine on my 516H. No filter but it is pressure lubricated. Unlikely to have valve seat issues thanks to the no filter but, a rod and maybe a piston with a quick hone on the cheap - maybe easy. Worth a look-see, especially in the off season in MD.
clueless
Down here especially with centipede grass cut 1 1/2 to 2 1/2 inches an 8 hp with 42 RD deck works fine, the SD takes more nut to blow the clipping out the side. Cut my 3/4 acre for fourteen years with a B80 4sp with a 42 RD deck. Clint (Anderson's Equipment) sold WH's here for many years and was a WH district sales rep, sold many 8 hp WHs with the 42" RD, he told me the engineers at WH told him with the shorter grass down here the 42 rd would work fine. They obviously didn't know about Pensacola Bahia grass :dunno: when that stuff gets high and thick you need a SBC to cut it and depending on how thick it is, that may need to be punched out. :handgestures-thumbupright:
Edited by clueless
RED-Z06
When i had my 310-8, .030over fresh engine, i put a 36"rd deck on and it never felt it even in 6" grass.  I put the 42sd on and it was a struggle, poor engine spent alot of time near 70% or 80% governor.  I thought maybe it was the rebuild...down on power.  When i got the low use C-100 i figured it would be more powerful being original.  Nope...if the deck is on the governor is open, head temps soar from 200⁰ to 266⁰ before it ever sees a blade of grass.
Thr 16hp Onan never touches the governor...itll smoke thru the belt first
Tim Ziethen
sounds like I should tear the 16hp Onan down first to see extent of damage - would love to rebuild - just reading how expensive parts and rebuilds are but will try that first - thanks to all!
pfrederi
Fortuneteller the Kohler web site has only very limited info about that spec. and my parts manual doesn't cover it at all.  Other research indicates you may have the 3 amp unregulated system or maybe a 15 amp system.  Is there a voltage regulator on the 310 tractor??  If not you have the 3 amp system.  You will have to rewire your lights to run off 12v AC direct from the stator (lights will only work engine running).  I do not know what other electrical requirement a 516 onan would have but 3 amps isn't a lot once you are running the ignition system...
Edited by pfrederi
RonnieB2nd
Some Kohler engines have a dash and it's different
  • Similar Content
    • rwlvt
      By rwlvt
      Hi folks,
      I tried to help a friend with a Toro 520H that won't start.
      https://photos.app.goo.gl/19fPX79LGMPCBcnB6
      (Attempting to insert a photo by URL doesn't seem to be working.)
      Here are some identifiers for the engine:
      Engine Model: P220G-I/109556
      P/N941811
      S/N:    A973636148
      I went through the usual--checking for spark.  I'm getting spark in both cylinders.  So, i'm looking at gas.  There is a fuel pump on the side of the engine.
      https://photos.app.goo.gl/RY4hHAfLLGeyCBaS8
      I pulled the gas line below it and am getting gas from the tank.  I pulled the line above it and cranked the engine.  I wasn't getting anything!  So, I assumed it was a bad fuel pump.  I ordered and installed a new fuel pump, but still no luck.  This is a vacuum actuated pump, so I pulled the pump and stuck my thumb over the tube while I cranked the engine.  I expected to get either a vacuum or compression.  I got neither.  Any thoughts about where I go from here?
      Thanks in advance,
      Ron
    • Rob R
      By Rob R
      Afternoon gentlemen friend of mine's father passed after a long illness, and he is now the owner of his Wheel Horse 416-8 with the Onan P216.  He wants to sell it to me as he has other tractors. I never owned and Onan Machine what advice can you give me. It has been in storage for 5 years and of course according to him "ran when parked" Has 365 hours on it. Thanks in advance going to look at it this Wednesday.
    • t_furl43
      By t_furl43
      A really nice 1995 wheelhorse 416H runs and drives great no leaks only 920 hrs, motor runs strong, starts right up, brand new back tires 23x10.5x12, has slot hitch, comes with 42” RD deck and 42” snowplow, wheel weights and all 4 hubcaps, I’ll also throw in an extra set of tires, will need a seat but that’s it, pickup in millersville pa 17551, price is negotiable, will trade for an Economy Powerking tractor or John Deere 318
    • Ifixoldjunk
      By Ifixoldjunk
      So I have a parts 310-8 I’ve been trying to get running. My problem is the engine runs for 5 minutes and then starts sputtering and shooting exhaust back out the carb. Any clue what is happening? I’m pretty lost.
    • richm1386
      By richm1386
      Quick story and a couple of questions concerning replacing the ignition coil on my '89 416-8 with Onan P216 engine.
      So I got this old tractor from my Dad when he replaced it and it was running okay until a few weeks ago. Was picking up sticks and hauling them out to the wood pile when I idled down the tractor and then it stalled out (which happens all the time.) I tried starting again and it would not turn over. The starter would go and go but no ignition. I spent a lot of time on these forums and found some really good info including the service manual. I used that diagnose the problem and figured out the coil was bad. I ordered a new off brand coil and condenser from Amazon for $40 swapped them in last night and it fired almost immediately. Plus since I had taken the shroud off and disconnected the throttle cable it was idling well at very low throttle. I've still got to reassemble everything properly but it seems like the coil was the culprit.
      That said I've got a couple questions.
      1. Anybody have any luck with non-Onan coils?The one I got from Amazon seems well made but it is literally some no name part. I figured for $40 it was worth a shot.
      2. Does it matter which spark plug attaches to which plug on the coil? I forgot to take a photo before I disassembled.
      3. Could a failing coil cause very hard starts and stalling at low idle? I'm asking because as I said above the tractor has been very hard to start for years. Almost always needed to choke it. It would also stall out if you idled down nearly every time. Just the brief testing with the new coil that I've done, both of these issues seem much better. Also I used my Dad's replacement (early '90s 416-h with same engine) for this tractor while working on mine and it started and idled very easily. It looks like it might have a replacement coil as well. Just wondering.
      Thanks all.
