Handy Don
Bringing back an 854
squonk
18 minutes ago, ebinmaine said:
I tried to tell @Handy Don Gorilla glue would work but my advice  "didn't stick"....
:hide:
Patrick Star Boo GIF - Patrick Star Boo Mr Krabs - Discover & Share GIFs   :lol:
  • Haha 2
richmondred01
I would consider taking it to a machinist. Taps that large will cost more for the tap itself then for them to do the job for you.
Just my two cents.
  • Like 4
Ed Kennell
Any local plumber should be willing to tap it for you or loan you the 1"NPT tap.
wallfish
Handy Don
Thank you all for the advice (except for the Gorilla clue :rolleyes:) and the offers.
Since even a phone call with my friendly plumber will cost more than buying a 1" tap, I'll be trying that first.
It looks like there's barely enough metal for carefully drilled and tapped holes for a flange like the one @Oldskool pictured. Could probably also do a flat ¼" plate with a threaded 1" hole (similar to an option on some 70's Tecumseh's to switch from the direct bolt-on mufflers to an exhaust pipe). Do you need special drills/dies for working the block? I have a set of cobalt drills I reserve for hard metals but my dies are carbon steel.
I'll post the results, for sure.
sjoemie himself
No special drills needed.
By the looks of it the head is cast iron, correct? If so do not use any lubrication. The dust will otherwise clog up your drill and/or tap.
Ed Kennell
I always use Kerosene as a lubricant when drilling and tapping cast iron.
  • Like 6
richmondred01
Cast iron has hard spots and isn’t as uniform steel. It’s a different technique and not as forgiving.
Pullstart
If you’re afraid of getting metal in the engine, you could just pop the spark plug out and blow air into the hole as you tap…. Grease also helps when tapping cast to keep the chips from moving too far.  @peter lena could tell you what spec, weight and color grease I’m sure :handgestures-thumbupright:  :lol:
richmondred01
Believe it or not we also used lard back in the day.
  • Like 5
Handy Don
I'm really hoping the tapping will work when I get my hands on a 1" NPT tap.
I like the idea of putting some air through the exhaust port while tapping--full face shield and safety glasses for that task!
richmondred01
Remove the exhaust valve and block the valve chamber with a rag.
When your done, Vaccum it out the prior to removing the rag. Once the rag is removed, put your finger on the top of the valve guide to block the hole, then blow it out.
I don’t recommend  using air pressure while tapping. It’s an accident waiting to happen.
Just my two cents from a guy that lost two fingers in an avoidable accident.
Edited by richmondred01
wallfish
:text-yeahthat:
or risk the Backyard hammer mechanic method which is NOT always the proper way. Just time saving and assuming you don't plan to go deep on that engine and just want to start and run it like it is.
Stuff a small damp rag in there and lay the engine on it's side ( Like using a milk crate or something) so the exhaust port is facing down and use gravity. But gravity also works against us older folks for getting up off the floor so plan ahead!
My philosophy being the chips and dust will fall, the rag keeps anything else from going deep and the exhaust blows out when it's started.
At least that's how I've done it sawing exhaust nipples to get those out. :twocents-02cents:
Handy Don
I am very appreciative of the continued advice, gentlemen, thank you! I've also been studying the Kohler engine manual.
I can see flowing air could be risky. Instead, I can see myself using the grease and rag method. Removing the valve seems like tempting fate as it makes an opening going down into the valve spring chamber. If it is out, though, then maybe a dollop of lard/grease in the guide hole that I can pull up and out after the tapping makes sense. As for the gravity thing, I've always hated working over head plus having the engine upright will help me keep the tap level going in. I have an adjustable height work surface that is pretty tall so I wouldn't have to lay on the floor, though (whew!)
I can see where this all this is leading now. Oh yeah, gotta get a valve compressor clamp. Oh, and I'll need a puller for the flywheel and bearing plate. And then a cylinder hone of course, and then who knows.... :lol:
Yesterday got the tins and head off and, from the top, it looks good. No oversize mark. Very little carbon. Almost indiscernible piston wiggle and no ring wear ridge or cylinder wall scratches that I can feel. Valve seats are clean and the valve heads are nicely proud of the top of the head--no pitting or blow-by that I can see on the valves or the head gasket surfaces. It had a full metal-sheathed head gasket, too, which I haven't seen in ages. Plug was clean and tan but also looks like a recent replacement (it is the correct spec though!) Possibly the head had never been off this engine before. Crankshaft endplay is within spec (~.014) and side play is indiscernible. Absent finding something of concern, I think I won't go any deeper in this engine.
I was going to get the carb off and then check the valve adjustment and points today, but I think I've caught the cold that my DIL and granddaughter brought with them earlier in the week so I'll be taking it easy today. Maybe spend some mindless time checking the head for flatness!
Oldskool
@Handy Don something else to throw in the mix. I have added a magnet to my chuck for semi low speed drilling to keep filings out of places. The only drawback I've seen is you have to clean the drill bit tip alot. It wants to recut the shavings if left in place. Ive used the same idea tapping threads.
I hope you have good luck in the direction you take on this.
Handy Don
This sounds intriguing! What does it look like?
Oldskool
It's just a standard magnet. I remove it when drilling "run of the mill" things.
I just let it stick to the chuck. That's why low speed.
Edited by Oldskool
richmondred01
Outstanding……
ebinmaine
5 hours ago, richmondred01 said:
Outstanding……
Agreed!
sjoemie himself
:text-yeahthat: not only good execution of an idea but also very clearly documented for future reference. Win-win in my book
Oldskool
Excellent.... Thanks for the visuals and the step by step. Hopefully years of trouble free use to come.
WHX??
Ok up to speed here Don and wished I'd been sooner. I have a 1" NPT tap I coulda loaned ya.
Not to be debby downer on the JB but I tried it on a exhaust once and it didn't hold up to the heat. Actually melted off but maybe your using a different type of JB?
epoxy is rated to temps well above what this K181 will throw off.
Ok just caught that. Let us know how it shakes. :handgestures-thumbupright:
  • Like 4
squonk
 Put a 1" conduit lock nut against the block to help secure the nipple.
They make hi heat JB weld.
J-B Weld 37901 Extreme Heat High Temperature Resistant Metallic Paste (3) -  Walmart.com
Pullstart
Best of luck with the longevity Don!  :handgestures-thumbupright:
