moe1965
Snow plow lift using pully
moe1965
Hello all I'm working on a project dont know how it will work out but on paper it should.  My blade on the 854 takes 52 lds of lift force to get it off the ground.  Using a pully it should reduce that effort by half. The only trade off  your giving up is your travel or lift of the blade off the ground reduces by half as well.  There are good videos on YouTube under Pullies that are very informative especially using ****** blocks to help big heavy jobs easier like removing stumps etc. check them out.  I hope to have time soon to work on it.  I'll keep you all informed.
  • Like 3
Jeff-C175
That looks like a great idea Moe!  I'm gonna think about that one.
There's another thread in which we've been kicking around ideas toward the same end:
SylvanLakeWH
Curious to see what you come up with…
Recent addition mail similar post:
Jeff-C175
14 minutes ago, moe1965 said:
using ****** blocks
The forum software thinks that " sn4tch " is a bad word!
As long as the lift arm has TWICE the 'throw' it needs, because halving the force required would mean doubling the distance, this would work well I think!  I'm gonna see if I can prototype something.
I know that on my 125, there IS excess 'throw', just not sure yet if it's twice as much as needed.
One could lengthen the arm to get more throw, but then I believe you would be adding back the weight due to the longer arm and the torque required.
Keep us posted how you do with your work Moe!
Edited by Jeff-C175
  • Haha 1
Pullstart
What about an assist spring?  It should help with loofa without sacrificing throw…
Jeff-C175
"loofa" ?  ;)
See the 'other' thread.  The assist spring reduces the down pressure of the blade.  I've got that setup on mine now.  Cuts the down pressure in half with the spring I've got on there.  I don't know if 40 pounds of down pressure is enough to keep the plow on the ground yet, but we'll see... soon enough I think!
Edited by Jeff-C175
Pullstart
Maybe in the right location, it could detent one way or another to assist with down pressure or neutralize?
Jeff-C175
1 minute ago, Pullstart said:
detent
Check out Greg's suggestion in the other thread.  He's got a slotted lever idea that would 'flip' the position of the spring.
  • Excellent 1
SylvanLakeWH
Or just go Popeye…
  • Excellent 1
  • Thanks 1
  • Haha 3
Jeff-C175
5 minutes ago, SylvanLakeWH said:
Or just go Popeye…
image.png.7ece7cafbf662920e6d8ec369961a387.pngegg egg egg ... :laughing-rolling:
Edited by Jeff-C175
  • Excellent 1
  • Haha 2
moe1965
Sorry about word.  I did see the other post about lift and have been following it as well. That's what got me thinking.  I tried a spring  last year but it had little effect. I thought of using a heavier spring but setting the tension to begin with and trying not to loose an eye in the process scared me.  I hope to work on it soon got all my parts then got hit by  covid. Under the weather a little now doing a lot of reading now.
  • Sad 4
roadapples
Hope you're feeling better soon
  • Excellent 2
Jeff-C175
1 hour ago, moe1965 said:
Sorry about word.  ......    got hit by  covid. Under the weather a little now doing a lot of reading now.
Not your fault that the dumbazz forum software doesn't know what a sn4tch block is!  :D
Get better soon Moe!  Can't wait to see what you come up with!  (and try it myself)
The spring I used (the piece of garage door spring) is actually SLACK when the blade is all the way up.  Very easy to hook up.
When raising the blade, it feels almost like a constant tension.  As the spring collapses, the leverage of the lift lever seems to increase somehow. I'll have to dig out my fish scale to check that.
Edited by Jeff-C175
  • Excellent 2
Snoopy11
Just be careful with those springs, boys...
Don't forget my "I almost lost an I..." thread... :unsure:
Don
  • Sad 1
Achto
2 minutes ago, Jeff-C175 said:
forum software doesn't know that a sn4tch block is!
10 minutes ago, moe1965 said:
Sorry about word.
"Block and tackle" would be a way around the "Sn4tch" word.:thumbs2:
ebinmaine
:popcorn:
  • Excellent 1
Handy Don
I got caught on the sn4tch word too! First time I'd seen that.
  • Haha 1
Ed Kennell
HYDRO LIFT
  • Like 4
  • Excellent 4
Wheelhorse#1
Interesting.I was just thinking this yesterday wile pushing snow around.
First thought was Dam !! getting old !
It would be easier if it was on the right side,if you are right handed that is.
I think a couple of pulleys might be the way.Less friction.
Ill be following this one.
killroy
I just move the lever up and the blade lifts.... lol
  • Heart 1
Jeff-C175
Yeah? OK.  One of my machines works that way too.
Do you have any suggestions on how to make it easier to pull a manual lift Killroy?
Edited by Jeff-C175
Handy Don
Do you have any suggestions on how to make it easier to pull a manual lift?
A ratchet mechanism could lessen the raising load at the expense of extra back and forth levering but I can't offhand think of a good way to lower it.
Jeff-C175
That question was actually for Killjoy ...  but since you mentioned a ratchet,  I thought about the way my el-cheapo come along reverses (and there's a mechanism on that very similar to the sliding spring lever that Greg had suggested in the other thread)  because I had looked at that for ideas.
Maybe just get a 1" Drive ratchet wrench and hook a foot pedal up to the reverser on that?  and use it for the handle...  but I jest.  Don't take this seriously please!  :ychain::hide::omg:
Edited by Jeff-C175
Handy Don
That question was actually for Killjoy ...  but since you mentioned a ratchet,  I thought about the way my el-cheapo come along reverses because I had looked at that for ideas.
The ratchet idea should have been accompanied by :hide:
Jeff-C175
Fixed it!  :laughing-rolling:
  • Haha 1
