Similar Content
By t_furl43
A really nice 1995 wheelhorse 416H runs and drives great no leaks only 920 hrs, motor runs strong, starts right up, brand new back tires 23x10.5x12, has slot hitch, comes with 42” RD deck and 42” snowplow, wheel weights and all 4 hubcaps, I’ll also throw in an extra set of tires, will need a seat but that’s it, pickup in millersville pa 17551, price is negotiable, will trade for an Economy Powerking tractor or John Deere 318
By Bill D
I picked up a low hour, (189.6) abandoned 416h yesterday. Does anyone know what size the o-ring is that seals the carb to the air cleaner? Mines cracked and I expected it to break in pieces when I remove it there by making it useless for sizing at the hardware store. Also, the voltage regulator is missing. Has anyone tried used a regulator from a Kawasaki as a replacement? I have a couple here and thought about trying them. Can anyone tell me if this engine has the governor spacer with the tab? Thanks.
By Tenday
Experts - help please. I’m new to Wheel Horse Tractor life!
So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
I’m looking for help on diagnosing no spark.
model - 417-8
engine - Kohler KT17
Done thus far: (aware that some have no implication on spark.)
- new ignition switch
- new battery
- new starter
- new ignition coil and wires w/ plugs
- new condenser
- new points
- new starter solenoid
- bypassed all switches except oil and seat.
notes:
idiot lights removed.
All fuses tested with Ohms as well as visual inspection ..
coil tested w/ ohms as well
all switches bypassed except:
-oil switch ( don’t think it has any implications other than a visual indication for idiot lights. )
-seat switch
ran a pos from batt direct to pos of coil - nothing; no spark.
Electric is as follows:
- Starter switch wired to solenoid
- - solenoid to starter
- - solenoid to batt
- one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
- I have two yellow wires, which are married up, that go to engine which have constant power; They power coil. Comes from switch and seat.
Help - what the heck am I missing ?
By Brockport Bill
416 Hydro Tractor For Sale - please see photos. Just over 700 hours on meter. Powerful Onan 16 Hp --- Has Automatic transmission and Hydraulic lift........New filters for tranny, engine, and fuel. New engine and trans oil. 2 new spark plugs. Only a few operating hours on near new Battery. Rear "Ag" Tires plus excellent tread front tires - Rims in excellent condition. Tin looks good. Front and rear lites work. New PTO safety switches. Also available For Sale is 48 inch re-conditioned mower deck for $425 - shell plus lift carriage assembly, all sand blasted clean to remove all rust, then two coats primer and two coats final top coat paint. Mower blades cleaned, sharpened and balanced. Rollers and wheels good condition. Also available For Sale: 48 inch plow unit - complete frame with necessary parts, springs, angle control lever, etc. Plus, like new re-conditoned blade had rust cleaned, then two coats primer and two final top red coats, newly welded reinforced iron bottom plate, plus rust cleaned and re-habbed painted wear edge blade with new carriage bolts @ $290. Also available For Sale: Rear Axle Bracket for plow, tiller, etc set up @ $65: All items cash pick up Hudson River Valley, Poughkeepsie NY area. Please Send private message to contact
By Don66
I have a 1978 Wheel Horse 8 speed tractor,Kohler 321 engine. I've been working on restoration, finally got the mower deck finished and installed. Before this, the engine was easy to start and ran well. Yesterday it would not start with ignition key, would not even turn over, so I jumped it with a screwdriver between cylinoid and battery. The engine started and ran about 10 seconds and died. Now I get no spark and the engine won't fire off. I checked the wiring and everything seems to be connected and without damage. I don't have test equipment available so I'm stumped at what went wrong. Any suggestions?
