pfrederi 19,264 #1 Posted January 3, 2022 K-181s originally fed the fuel line behind the engine bearing plate and the block through the same area the stator output wires and coil power feed went. I would imagine it get warm back there but back then it was heavy rubber (neoprene) line. Has anyone put the modern blue line or the yellow Tygon stuff in there?? Thoughts??? Share this post Link to post Share on other sites
ebinmaine 75,747 #2 Posted January 3, 2022 I routed my B80 line down the bottom of the front cover like on a big block. Trina's 867 goes to the opposite side. In both cases I try to hold the line as still as possible. 1 Share this post Link to post Share on other sites
Ed Kennell 43,783 #3 Posted January 3, 2022 No experience here Paul, but I see the yellow tygon fuel line is rated to 165F. Should be OK. Share this post Link to post Share on other sites
RED-Z06 2,690 #4 Posted January 3, 2022 I wont use the poly line in my shop, or on my own stuff. Good for a couple years but if its going to be exposed to the sun any time...the stuff just falls apart. I cringe when i think about the hundreds of feet of it ive sold.. Share this post Link to post Share on other sites
pfrederi 19,264 #5 Posted January 3, 2022 6 minutes ago, Ed Kennell said: No experience here Paul, but I see the yellow tygon fuel line is rated to 165F. Should be OK. What i was worried about is what happens when you first shut down and there is no cooling air flow would seem the temp would go up for a bit then settle. Share this post Link to post Share on other sites
Maxwell-8 4,370 #6 Posted January 3, 2022 49 minutes ago, RED-Z06 said: I wont use the poly line in my shop, or on my own stuff. Good for a couple years but if its going to be exposed to the sun any time...the stuff just falls apart. I cringe when i think about the hundreds of feet of it ive sold.. 46 minutes ago, pfrederi said: What i was worried about is what happens when you first shut down and there is no cooling air flow would seem the temp would go up for a bit then settle. Head temp easily reach 250°F as RED-Z06 showed the other day Share this post Link to post Share on other sites
